wierd volvo((( I'm dissapointed, really... fuel problems
Discussion in 'Volvo Forum' started by Pablo-UA, Jan 11, 2014.
  1. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    Ok, got really unusual problem.
    Volvo with D12D engine in workshop... wont starting. Starter cranks engine, it fires and stalls blowing black smoke!
    when it starts ECM reads 0 gal per hour, like leaking hard injectors, but injectors and sleeves are new. Other problem, low fuel pressure, less 5 PSI with new fuel pump and new fuel pressure limiting valve.
    So things look like fuel leak to intake ore to cylinders from cylinder head, aka crack in head, but I've never seen this problem before.
    If someone had, plz tell about this.
    In monday I wanna do pressure test of cyl. head fuel passages..... but seems to me it is time to call mechanic to remove head!
  3. nasriza
    nasriza Road Train Member
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    Pablo check to see how th accesory drive looks being that it drives the pump everytime i change fuel pump on d12d accesory is usually done and they need to be replaced as a pair if accesory worn out bad it wont drive properly also. Check and maybe replace the fuel filter housing they have a lot of problems feom that #### as far as the drain back valve are u talking about the valve on the intake manifold. Ive never heard of a head being cracked on the fuel passage or seen it for that matter also possible is bad injector. Let me know what it turns out to be please cuz i deal with d12d on a daily basis and would like to know. Also very possible is a bent valve ive had that before with black smoke. But the engine when running ran like #### no effect on fuel psi. Is the any kind of mixing going on as far as fuel and oil or coolant
  4. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    some inj. are bad out of box, can you press, ck. for leak/down of fuel, had 2 bad out of 6, right out of box did same thing.
  5. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    well, lets wait for pressure test
  6. markster1957
    markster1957 Light Load Member
    65
    22
    Jan 21, 2014
    boise id
    check and see if the egr valves are stuck open
  7. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    today it is very cold here so I did pressure test outdoors.
    failed....
    removed exaust manyfold and found that fuel is in #2-3 exaust passages
    I sugest cracked head
  8. markster1957
    65
    22
    Jan 21, 2014
    boise id
    The heads are very tuff I would think more like injectors or cups are u doing this at home
  9. markster1957
    65
    22
    Jan 21, 2014
    boise id
    I would look very carefully at injectors /cups/rockers/ engine brake pistons in the rockers
  10. markster1957
    65
    22
    Jan 21, 2014
    boise id
    When u check the pistons in the rockers make sure the back of the piston has not come unscrewed it should be flat
  11. nasriza
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    Did u properly adjust injectors possible cup not sitting right or damaged
