will a toe in problem cause a bounce
Discussion in 'Trucks [ Eighteen Wheelers ]' started by earthmover, Dec 6, 2013.
  1. earthmover
    earthmover Medium Load Member
    563
    20
    Jan 27, 2009
    castalia , north carolina
    hum ok I had I bounce before I put this tires on but not as bad...so what did you end up putting on..when I do the work I will endup putting new tires on again...I really want my truck back to the way it was and should be..
  3. grump
    grump Light Load Member
    74
    29
    Jan 1, 2011
    PA
    Well I have had less bounce with the bf Goodrich ,continental is what I try to run I have a few friends running hankook , I go through a set a year and sometimes 2 yokahama was another bad one ask around see what local guys are putting on in your area I have ran bout all that's out there that's what I settle for I never ran off brands on the steer most dealers in my area wont sell a china tire unless it will be used on a tag axle hope this helps.
  4. earthmover
    563
    20
    Jan 27, 2009
    dang I need to stop crying a set a year man that's got to hurt...I do go about 2 years on my tires ....also I try to keep them swapped from side to side after a few oil changes...but thanks for the info ...I will see whats going on when I put tit in the shop and hope its not to bad..
  5. ironpony
    ironpony Road Train Member
    17,502
    12,015
    Sep 23, 2007
    Ask my GPS...
    You betcha! Had a severe toe in problem (thanks TA) - and it made the truck almost undriveable.
