Will adjusting the clutch increase my acceleration power??
Discussion in 'Ask An Owner Operator' started by jpgale22, Jul 13, 2017.
  1. jpgale22
    jpgale22 Light Load Member
    149
    15
    Apr 12, 2016
    will adjusting the clutch increase my acceleration power?
  3. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
  4. rabbiporkchop
    9,679
    6,548
    Feb 9, 2012
    Wapwallopen, Pa
    Depends on if it needs adjustment or replacement. Without knowing, we can't give you an answer.
    Grubby and jpgale22 Thank this.
  5. Alaska76
    Alaska76 Road Train Member
    1,228
    1,653
    Jan 20, 2014
    Inland Empire, WA
    If it is slipping it will, provided it does not need replacement. Otherwise, you have a different issue.
    Grubby, Bean Jr., ExOTR and 2 others Thank this.
  6. nasriza
    nasriza Road Train Member
    2,409
    2,078
    Feb 1, 2013
    Chicago, IL
    usually no if you can get it in gear just fine than most likely you dont need adjustment if it is however slipping you do but if it slipping you will barely be able to move.
  7. jpgale22
    149
    15
    Apr 12, 2016
    My mechanic said it did but I really don't think that's the problem I lose speed going up hills
  8. jpgale22
    149
    15
    Apr 12, 2016
    He said it needed an adjustment I don't think that's the problem but I lose speed going up hills and even I push the accelerator down to the ground and still losing power
  9. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
    So is the clutch slipping or not?
  10. nasriza
    2,409
    2,078
    Feb 1, 2013
    Chicago, IL
    BEST I CAN ADVISE YOU IS GO TO A DIFFERENT MECHANIC sorry to be the bearer of bad news
    nax, AModelCat, skellr and 5 others Thank this.
  11. Alaska76
    1,228
    1,653
    Jan 20, 2014
    Inland Empire, WA
    Umm, you do know that in order to combat gravity more power is required, and that shifting down is usually required, and in turn that means going slower as a result of said actions and gravity?
    uncleal13, AModelCat, tinytim and 4 others Thank this.
