Window opens door?
Discussion in 'Kenworth Forum' started by tnpete, Sep 6, 2018.
  1. tnpete
    tnpete Medium Load Member
    561
    609
    Jun 25, 2013
    Tn
    Anyone had this issue? Roll the pass door window down,and door pops open. Window hits the rod that opens the door from the outside? Pushing that rod down, and door pops open. When I bought the truck that pass door would not open from the outside. But only from the inside.
    Figure they had the same issue. So fixed the rod where it can't hit. And allowed the window be rolled down. But not open from the outside. Took both doors apart, where I could look at the Drivers side and pass side rods. And if it the pass hooks up the same way. Then I had it right.
    Wondering if the Kenworth rod clips are Thinner then the one on it? Sure sucked running 60, went to roll the window down. Door popped open.
    Anyone have or know where I can find a pic of the pass door linkage? 1995 T600.
  3. bzinger
    bzinger Road Train Member
    16,659
    66,217
    Dec 10, 2014
    omaha , ne
    Cool way of getting rid of unwanted passengers lol
    AUfan78, Tacomatrd99 and Justrucking2 Thank this.
  4. boneebone
    boneebone Road Train Member
    2,297
    2,372
    Mar 13, 2009
    Go to the KW stealership, they should be able to print you a picture from their parts diagram breakdown of the door.
  5. tnpete
    561
    609
    Jun 25, 2013
    Tn
    Can't get the locak KW Dealer to print much of anything. Unless its the bill. Going to see if a buddy of mine might have it tomorrow.
    May just add an ejection seat, and take a few for a ride of there life.
    bzinger Thanks this.
  6. bzinger
    16,659
    66,217
    Dec 10, 2014
    omaha , ne
    I've got a few ex's you can use for test subjects lol
  7. tnpete
    561
    609
    Jun 25, 2013
    Tn
    Rent it out by the day. o_O
    magoo68 and bzinger Thank this.
  8. bzinger
    16,659
    66,217
    Dec 10, 2014
    omaha , ne
    Lmao !
  9. J Rich
    J Rich Medium Load Member
    363
    380
    May 28, 2018
    Atlanta Ga
    I'd pull the door panel off, and see what is doing. The window regulator may be loose or missing a bolt.
  10. tnpete
    561
    609
    Jun 25, 2013
    Tn
    Turned out the glass was hitting the release rod. Changed out the lock rod clip. And its working right again.
    J Rich Thanks this.
  11. J Rich
    363
    380
    May 28, 2018
    Atlanta Ga
