Window regulator?
Discussion in 'Western Star Forum' started by Perchie15, Sep 4, 2024.
  1. Perchie15
    Perchie15 Light Load Member
    257
    75
    Aug 16, 2021
    The manual window on DS, likes to go down by it self! Is there a spring or something that I need to replace? Always needs tension on the knob to keep it up.
  3. Numb
    Numb Crusty Curmudgeon
    4,477
    10,891
    Jan 30, 2012
    Charlotte, N.Carolina
    "needs tension on the knob to keep it up."
    me too.
  4. SmallPackage
    5,960
    19,213
    Dec 20, 2019
    Marion Texas
    With window all the way up pull the handle off if you can and reinstall with it hanging down at the 6 o’clock position. Sometimes just vibration and the weight of the crank handle sitting anywhere else will cause it to rotate down pulling the window open with it.
    motocross25 and beastr123 Thank this.
  5. Perchie15
    257
    75
    Aug 16, 2021
    When it’s all the way up it doesn’t seem to come down but half way or so then it’ll come down easily weird how that is. Tried your trick n no go
  6. SmallPackage
    5,960
    19,213
    Dec 20, 2019
    Marion Texas
    Is there anyway to tighten up the glass runners by bringing them in closer to the glass to put more of a squeeze on it. Many have bolts and oversize or slotted holes to do adjustments.
  7. SmallPackage
    5,960
    19,213
    Dec 20, 2019
    Marion Texas
    When the glass falls down does the crank rotate with it? If it doesn’t i’d be thinking it’s some bad teeth on the gear or rollers on the regulator arms causing the drop. Both are probably plastic.
  8. Perchie15
    257
    75
    Aug 16, 2021
    No the teeth are fine. Roller goes along with it too. And yes plastic
