Winnebago county IL Weight limits
Discussion in 'Other News' started by n9mxq, Mar 8, 2013.
  1. n9mxq
    n9mxq Light Load Member
    145
    66
    Aug 13, 2010
    Belvidere, IL
    Not that many here will be in the county, but thought I'd post this:
    Winnebago County releases spring weight allowances ..
    5:03 PM
    Spring is on its way and the annual freeze and thaw cycles are softening our roads.
    In response, Winnebago County Highway Department are temporarily restricting heavy trucks from certain roads. Those roads will be marked with signs and the typical spring road posting period is four to six weeks.
    Enforcement of spring weight postings will begin on March 11. The posted limits are:
    Two axle vehicles with single rear tires - 9,000lbs
    Two* axle vehicles with dual rear tires - 20,000lbs
    Three* or more axles with dual rear tires - 33,000lbs
    For School Buses:
    Two* axles with dual rear tires - 25,000lbs
    For Garbage Trucks:
    Three* or more axles with dual rear tires - 42,000lbs
    *Gross axle load of 13,000lbs.
    No bits were harmed in the posting of this message.
