Winter Weather Driving
Discussion in 'Experienced Truckers' Advice' started by dodgeram440rt, Dec 28, 2015.
  1. dodgeram440rt
    dodgeram440rt Heavy Load Member
    840
    601
    May 19, 2009
    Piqua, Ohio
    This is gonna sound like a stupid question, but it's one we all have to deal with, so here goes...
    How do y'all keep your windshields clear when driving in the snow? I drive a Cascadia and my wipers keep building up with snow. Doesn't matter if I use the covered winter blades or not, the snow sticks to the rubber blade and holds the wiped away from the windshield, effectively making it useless. I've tried cranking the defrost on hi heat, hoping to heat the windshield enough to avoid any build up, but that doesn't work. I've seen gimmicks like heated wiper blades and heated washer fluid, but I'm skeptical and don't want to throw money away on stuff that isn't gonna work. One thing I hate about Cascadia wipers is they come factory with 24" blades, but even with 22" blades, the top two inches is pretty much useless. Even in rainy conditions, that top two inches just smears the grime.
    So what to you guys do?!?
  3. hunted
    hunted Medium Load Member
    I do nothing I just let the snow build on my windshield and use the FORCE to drive. Driving is all feel ya know
  4. mountaingote
    mountaingote Road Train Member
    2,026
    7,916
    Sep 22, 2012
    Reach out and knock the ice off when it gets too bad
  5. americanmadetrucker
    americanmadetrucker Logistical Engineer
    896
    3,280
    Jul 3, 2012
    I never use defrost when its just snow. Put it on the floor. Keep the windshield cold. I have a 2016 Cascadia myself. Also, winter blades are a must. 20" blades for the Cascadia. Just buy some and turn receipt in. Or if they won't reimburse you. Its the best 35 bucks ya ever spent.
    Lepton1, pattyj and Alberta trucker Thank this.
  6. ZhenyaP1991
    ZhenyaP1991 Medium Load Member
    573
    702
    Nov 6, 2014
    I know. idk if you driving around wi today, but man. I am done with snow already. I couldnt handle it today. I pulled over and refused the load. I had 3 cars slide in to the ditch, hoping others would learn something. But nooo, I felt like they sped up. But to help you out. Pull your visor down, so it can trap heat a little bit and dont use wipers to much.
    tucker Thanks this.
  7. americanmadetrucker
    896
    3,280
    Jul 3, 2012
    Four wheelers today were in the median, in the ditches and two way out in a farmers field coming across 80/90 in Indiana. I kept going, but eased her across.lol
  8. tucker
    tucker Road Train Member
    12,647
    40,425
    Jun 13, 2008
    IN
    Some days I'll put on a heavy sweatshirt and sock cap and freeze so I can keep the windshield cold so the snow bounces off,
    When it builds up I'll scunch forward, reach out and grab the wiper to knock the ice off.
    And sometimes whatever I do, it just plain sucks to see
  9. STexan
    STexan Road Train Member
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    If it's between 28 and 32 F there are no good options. Keeping the windshield "cold" will not keep the wet snow from sticking, plus you'll end up with iced over glass. There are no good options with wet snow. If you have long arms you can reach around and "snap" the wiper assembly but this is not safe, but safer then driving with no visibility.
    Also, in 28-32f conditions and wet snow, run the heat and defrost wide open to the point you can't stand it and this will allow some heat to transfer through the blade as a temporary solution. A lot has to do with the wind speed and direction, but the freight liners are bad about funneling the snow to the tips of the blades and accumulating.
    You can try the "spring boosters" that try and keep the blades more firmly against the windshield but these have mixed results according to what I've read.
    Dry snow when it's really cold is usually not an issue. Just keep the heat directed to the floor, and this usually allows the snow to bounce right off before any melting/sticking.
    Lepton1 Thanks this.
  10. rank
    rank Road Train Member
    9,919
    113,510
    Feb 11, 2010
    Ahhh the eternal question.
    Winter wiper blades are a must.
    Yes cold air on the def works but if there's road spray or freezing rain it doesn't work so good.
    Yes sun visors down to trap hot air helps alot.
    Some trucks you can reach the wiper and some you can't.
    This year (if winter ever gets here), just for fun I'm going to try rigging up a heated handle bar kit from a snowmobile onto my wipers or my windshield.
    americanmadetrucker Thanks this.
  11. STexan
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    Also with the freightliner, I have found it best to not put the wipers in delay mode, run them on normal continuous so as to not allow more additional snow to accumulate at the tips when they sit in their idle position.
    White_Knuckle_Newbie Thanks this.
