wiper intermittent relay location
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by markk, Jun 1, 2022.
  1. markk
    markk Medium Load Member
    Nov 14, 2011
    566
    Thanks Received:
    197
    Trying to find location of the relay.
    Only have a few delay settings and low speed working. I assume this is the relay going bad.
    Thanks
  2. Goodysnap
    Goodysnap Road Train Member
    Jul 12, 2017
    3,744
    Thanks Received:
    9,105
    Wiper relays and fuses are in the under hood fuse box.
    blairandgretchen Thanks this.
  3. markk
    Nov 14, 2011
    566
    Thanks Received:
    197
    I meant the controller that switches the speeds of motor. I heard it was inside the lever on steering wheel. Also that it was under dash. But I can't even find one for sale so I can see what it looked like. I assume these days it would be a microcontroller.
    But I guess it could just be contacts inside the lever as a rotary switch
  4. kranky1
    kranky1 Road Train Member
    Sep 16, 2015
    2,253
    Thanks Received:
    8,854
    Ontario, Canada
    It’s just a switch in the turn signal. You’re looking for the blower motor resistor. If those trucks are the same as KW’s it’s buried inside the dash on the passenger side where no sane person would have put it.
    markk Thanks this.
  5. markk
    Nov 14, 2011
    566
    Thanks Received:
    197
    Not the blower motor. The wiper motor. I need to find the Intermittent relay/ controller that changed the wiper speeds and delays. I think it is inside the turn signal lever but not sure.
  6. kranky1
    Sep 16, 2015
    2,253
    Thanks Received:
    8,854
    Ontario, Canada
    That’s a mystery to me. All I know about the electrical system in those newer trucks is that I don’t want anything to do with them. The flasher is electronic, I’d imagine the wiper speed/delay probably is too. Might be in the steering column, that’s what would make sense, but engineers being engineers it could be buried almost anywhere.
    markk Thanks this.
  7. kranky1
    Sep 16, 2015
    2,253
    Thanks Received:
    8,854
    Ontario, Canada
    I just looked at a picture of the turn signal switch for that truck. That looks like a pretty big box on there to only have the signal and dimmer switches in it.
    markk Thanks this.
  8. markk
    Nov 14, 2011
    566
    Thanks Received:
    197
    Yep. This Pete is a wiring nightmare. Lots of problems. Hvac controls don't work right. Have to manually open and close hot/ cold door and that is a pain.
  9. markk
    Nov 14, 2011
    566
    Thanks Received:
    197
    It must have a switch in it since turning the "knob" on blinker arm clicks for each position just like most vehicles.
    I'll pull it out and find out.
