wireline operator oil field: Advice
Discussion in 'Oilfield Trucking Forum' started by ChancesRGood, Nov 12, 2017.
  1. ChancesRGood
    ChancesRGood Light Load Member
    184
    224
    May 28, 2017
    I have decided to go back to oil and gas... i was formally a data and excel guru as a Engineering Tech when i was laid off... I have a degree in physics and now a cdl with 2 months experience driving semi's ... I was wondering if any of you had some tips for me ... what certifications, skills, things to do that would help me go into wireline??
  3. Justrucking2
    Justrucking2 Road Train Member
    3,211
    4,295
    Sep 12, 2017
    Plymouth MI
    Apply for a job, long hours and physical, not much driving. I would start with a water hauling gig, vacuum truck, if you are wanting to work in the patch. That will more than likely expose you to many of the other opportunities out there and keep you busy. Starting pay is anywhere from $17 an hour up to $25 depending on the region. Not that great, but it will get your feet wet. The further North you go, the better the pay. I was at $25 an hour in ND hauling water. Then I moved to Propane and Y Grade, that bumped me up to $32 an hour, their equipment.
    ChancesRGood Thanks this.
  4. Rodeorowdy
    Rodeorowdy Light Load Member
    169
    145
    Jul 3, 2013
    Anchorage, AK.
    With your credentials, I would apply to every company that has the wireline division.
    It's not a driving job, so your two months of experience would be adequate, In my opinion.
    Go Wireline, MBI, Canary, Pioneer, Schlumberger are but a few.
    Just google "wireline oil field services".
    rabbiporkchop and chalupa Thank this.
  5. driverdriver
    driverdriver Road Train Member
    4,254
    5,284
    May 30, 2011
    Trucking just isn't all that glamorous as it's made out be. Is it
    Especially that team driving.
    Good luck on your new adventure.
    No, I'm not being sarcastic. Lol
  6. Jazz1
    Jazz1 Road Train Member
    2,373
    4,971
    May 7, 2012
    Thunder Bay On
    Contact a company that does wireline. They will fill you in. Wireline on the offshore rigs is a better gig.
    rabbiporkchop Thanks this.
  7. I glide 47
    I glide 47 Road Train Member
    1,426
    1,523
    Jun 3, 2017
    Start with cased hole understand that first then maybe open hole you will need thick skin some of the people who are there are old school no women in the patch. Best of luck. I. Glide. 47
  8. ChancesRGood
    184
    224
    May 28, 2017
    well I have a job offer now but their training to be a wireline operator doesnt start till jan so in the meantime I will be a hot shot flat bed driver for them driving a pickup and goose neck trailer
    Rodeorowdy and Jazz1 Thank this.
  9. Dick Danger
    Dick Danger Medium Load Member
    545
    766
    Dec 19, 2014
    Seattle
    E-line or slick line? Slick line IMHO is a better gig. Unless being stuck on location for days and days with no end in sight appeals to you.
  10. ChancesRGood
    184
    224
    May 28, 2017
    I dont know yet but I will keep an ear out
  11. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,060
    Nov 18, 2014
    Land of local
    You realize she has an engineering degree that's already a foot in the door
    I would much rather be on a wire line crew than driving a water bottle. You know how many times I run into wire line at a rig and they're cabbed up sleeping and getting paid for it. Wire line will open up more doors than a water truck driver. By any means I'm not saying turn down an offer for water truck if you get one hop on it get your foot in the door at least. Wire line experience and your worth way more than a water truck driver that's a dime a dozen.
    Have you been around wire line? Running a vac truck is more labor intensive. Out of cement, frac, coil-tubing, wire line is one of the sweeter gigs.
    Check out nine wire line, KLX, Schlumberger, Halliburton, bj services, Cudd and a bunch of other smaller companies
    @ChancesRGood where are you located? Southeast Ohio wv and southwestern pa are booming again setting some world records in terms of latteral length of wells. I pre-loaded a cement job that set a world record 19.5k latteral distance total depth 27,750 in just 17 days. HP #608 was the rig. One of their old ones too not those new giant flex rigs that can walk any which way
    Eclipse Breaks Record Again – New Longest Shale Well in World!
    Don't let being a woman scare you one of my co-workers is and she doesn't take #### from anyone. She came in fresh cdl in hand from cr England after 2 weeks there she said f this. Just make sure your skin is real thick you'll do fine. Any bs my co driver got was from the rig hands all the company men I dealt with were pretty laid back actually
