wobbling when driving Tri axle
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by SA1, Jun 25, 2021.
  1. SA1
    SA1 Bobtail Member
    11
    8
    Jul 25, 2019
    Hi guys/gals
    my 2014 Tri dive kenworth is wobbling when I drive and the faster I go the more it wobbles.I noticed the first rear axle has started to get an uneven tire wear. I’m change out the shocks on the rear front and middle axles.This is my first truck so I want to do the most I can myself. Don’t want to be down a whole day either. Shocks look simple two bolts anything I should know? any other problems I should keep an eye for other then the shocks?
    thanks I’m advance eveyone
  3. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    -Get a 10 or 15 ton bottle jack and and tire changing bar, then jack up each side with big blocks of wood for tire chocks on each side of tire on other side that your jacking on and use the long bar to ck. for lose wheel bearings for any play at all with brakes released that can make the outside edges of drive tires wear funny ridges, look at the arms that hold axles in line that have rubber bushing inside them that should look solid all the way around and can make axles act like that if they are worn ? CK the ft. end steering box arm for any play by turning the shaft with motor running and ck. both tie rod ends for any play, then jack up each FT. side and ck. for any wheel bearing play?
    BoxCarKidd, Dino soar and Don379 Thank this.
  4. Don379
    Don379 Heavy Load Member
    714
    1,286
    Jan 7, 2021
    That about covers it where to start
  5. 201
    201 Road Train Member
    12,791
    26,324
    Apr 16, 2014
    high plains colorado
    Not the shocks, is the 1st axle an air tag? I doubt you have 3 drive axles, it may be a downward pressure thing, or not enough. If it's a drive axle, the list is long. U-joints, bearings, engine mounts, harmonic balancer, tire with a bad cord. If it is a tag, I'd look at the tires 1st. An old rule of thumb, if the shaking is in the steering wheel, it's up front, if it shakes the seat, it's probably a driveline issue.
  6. SA1
    SA1 Bobtail Member
    11
    8
    Jul 25, 2019
    Sorry for the late answer. I got caught up setting the truck up I failed to mention they were off road tires and I did geta front mount hiab on the truck got a deck attached to it also. the wobbling has almost stopped now but I’m assuming the off road tires are going to cause some wobbling. I’m getting them changed out and the tread has evened out after 2 weeks of on the road now. I guess it needed some weight on it. I did go thru the steps other then a wheel seal leak ( fixed now) it runs better and didn’t find anything wrong. Thanks for the help
