I had a drive cam that uses a SD card.
I forget about perhaps formatting the card?
First time I downloaded a couple videos from it. Then trashed everything there. Saved ones won't get wiped off unless I do it with a computer.
Then used it again.
This time checked it. I got nothing there?
Should I have formatted it again? Or?
Working with SD card
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by WesternPlains, Feb 22, 2020.
Depends on the dashcam. My BlackVue, I just hold down the power button for a few seconds, then it will beep, format the SD card and install software on the card so it can be viewed on a Mac or PC computer.
If you're being asked to format. Beyond the first time. The card might be getting worn out.
That's usually what happens on the computeruncleal13 Thanks this. -
Dashcam sd cards last me a couple years with daily use. YMMV
This is a large card. I can record overnight. It's also a very high quality card. Not cheap.
I let it go. Recording constantly. I only had a couple things on there where I pushed the emergency button to keep it. Otherwise it records over past recordings.
