worry about this or no
Discussion in 'Freightliner Forum' started by 4noReason, Jun 11, 2020.
  1. 4noReason
    4noReason Road Train Member
    2,401
    757
    Nov 29, 2012
    my air pressure did this. 12.7 d60. glider .
    it did this like once or twice last night. i chamged my air dryer filter like 2 weeks ago
  3. bad-luck
    bad-luck Road Train Member
    3,442
    6,349
    Nov 16, 2013
    Baltimore, Maryland
    Sounds like an air pressure regulator. It mounts to the air compressor. Its around $50. The ones with the blue plastic cap are factory set and non adjustable. Black cap is adjustable. Hope this helps
    4noReason Thanks this.
  4. 4noReason
    2,401
    757
    Nov 29, 2012
    is it called a governor?
  5. nikmirbre
    nikmirbre Road Train Member
    5,593
    10,362
    Jul 27, 2011
    High Point NC
    Also called a governor
  6. 4noReason
    2,401
    757
    Nov 29, 2012
    thx. so u dont think its my air dryer
  7. bad-luck
    3,442
    6,349
    Nov 16, 2013
    Baltimore, Maryland
    Yes
  8. bad-luck
    3,442
    6,349
    Nov 16, 2013
    Baltimore, Maryland
    The air governor is what tells the air dryer purge valve to open when the maximum set pressure is reached
  9. bad-luck
    3,442
    6,349
    Nov 16, 2013
    Baltimore, Maryland
    Here is what they both look like
  10. nikmirbre
    5,593
    10,362
    Jul 27, 2011
    High Point NC
    No not your air dryer. In the pictures above Ive got one with a blue cap. Its preset NOT to go above 125 psi, its not adjustable.
    The black one, Has I believe like a screw or something that you can make control what psi is set to. Yours might need to be dialed back a bit. With that said, my old Columbia mine use to go right where yours was for years, no problems.
    You're worried...4noreason... :D
  11. Rideandrepair
    17,573
    56,928
    Aug 8, 2015
    If it’s only occasionally, it may be just be the gauges. I hit them, sometimes and they’ll read correctly. 125-130 ok
