X- misssion problem
Discussion in 'Volvo Forum' started by sammaxlee, Aug 10, 2019.
  1. sammaxlee
    sammaxlee Bobtail Member
    33
    Jun 20, 2019
    I have 2014 volvo i shift X -mission.I put the gear from "N" postion to "D"or"R" but it is not engaged some time ,not allthe time
    could you explain to me that what a problem is and advise to fix
  3. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,139
    Mar 5, 2016
    White County, Arkansas
    Did you apply braking when you made the shift?
    KB3MMX Thanks this.
  4. nasriza
    nasriza Road Train Member
    2,398
    2,074
    Feb 1, 2013
    Chicago, IL
    very possible CCA is going need to see if you have any codes seems like clutch issue.
  5. Rob100100
    Rob100100 Light Load Member
    206
    122
    Mar 5, 2016
    You might have had some codes earlier or some sign of failure. You will need to take it to a dealership for them to open the transmission up. If there are any none dealership shops dealing with I shift transmissions you can try them as well. Sorry but there are very few choices with this kind of problem except to get it to a shop.
  6. nasriza
    2,398
    2,074
    Feb 1, 2013
    Chicago, IL
    There is absolutely nothing you can really do i shift is definately not friendly to people working on their own trucks mainly cuz you need software to calibrate clutch check everything even if you want to open transmission and close it you need special cables and also need to set gears before you open and also calibrate when you close, even shops around unless they have worked with it before i would really not trust them with this they need to have Power tech tool for them to even be able to touch anything or other than that dealership is the only way.
    KB3MMX Thanks this.
  7. sammaxlee
    33
    Jun 20, 2019
  8. sammaxlee
    33
    Jun 20, 2019
    thanks a lot every one
