X-Ray cargo scanner at Port
Discussion in 'Questions From New Drivers' started by MrTrans, Mar 23, 2016.
  1. MrTrans
    MrTrans Bobtail Member
    15
    6
    Dec 1, 2015
    Does anyone has ideas on how harmful is the x-ray cargo scanner at the port and rail?
    Is it the same kind as the one in hospital?
    Thank you for any input!
  3. street beater
    street beater Road Train Member
    4,578
    20,669
    Apr 18, 2014
    cold as hell, MN
    Only harmful if the balloons full of herion in your belly burst....
    77fib77, S M D, Brettj3876 and 2 others Thank this.
  4. Tai
    Tai Medium Load Member
    Every time I've been xrayed at the border they either have me get out of the truck or they only scan the trailer.
    Dumdriver and MrTrans Thank this.
  5. mindes
    mindes Medium Load Member
    626
    540
    Feb 17, 2015
    Crestview, Fl
    Just don't get angry afterwards.
    MrTrans and northernhopper Thank this.
  6. northernhopper
    northernhopper Light Load Member
    260
    367
    Mar 15, 2015
    isanti mn
    They always xrayed sleeper on back with me. But then i set of radiation alarms to. Hauling potash.
    MrTrans Thanks this.
  7. MrTrans
    15
    6
    Dec 1, 2015
    Oh yeah, i get in and out the port 4 to 6 times a day. Everytime, i have to drive the truck through that machine. Scare of "smoke" too much that radiation. image.jpeg
  8. lfod14
    lfod14 Road Train Member
    1,178
    689
    Jan 9, 2014
    X-Rays are X-Rays. Pretty sure they don't turn it on until your truck is through. On the rare occasion I wind up at the port near me they don't have the permanent ones, they have the 2 truck setup and Thiers a light so I know I'm not getting nuked
    S M D and MrTrans Thank this.
  9. MrTrans
    15
    6
    Dec 1, 2015
    I dont know if they turn it on and off or not but i see trucks just go through those machines 5 mph not even stop. If i pick up 4 containers a day, i will get scanned 8 times. Check in scan and check out scan again.Thats scare me!!!
    ncmickey Thanks this.
  10. IronWeasel80
    IronWeasel80 Medium Load Member
    387
    375
    Sep 4, 2015
    Belen, NM
    Exactly.
    The major difference is in how much energy is used to produce the desired results. When you get an x-ray on your body, it's pretty safe since the machine uses a relatively small amount of energy since human flesh is easy to penetrate. When you need to be able to penetrate steel or other dense materials, the energy need rises as well.
    However, even with the increased energy needs, you are still only exposed to a relatively small amount of energy, generally around (or less than) 0.1MeV (Mega electron volt) per scan.
  11. northernhopper
    260
    367
    Mar 15, 2015
    isanti mn
    Those scanners in the pic may be radiation sensors also
