X15 constant regen
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by 99kw900, May 21, 2025.
  1. 99kw900
    99kw900 Bobtail Member
    39
    186
    Feb 26, 2020
    I have a 2024 w900 with a cummins x15 565 hp engine with just over 235000 miles on it. So far I've had no issues whatsoever with anything engine related but recently it started acting like it was running regens more often, except I really don't think it is doin a regen. I get the higher idle, the added boost, and it only does it when the engine is not under a load, (like when I'm waiting at a stop sign, after I park somewhere it will do it for 2 minutes or so but then will idle normally) the high exhaust temperature light never comes on like it doesn't when it is normally running a regen cycle. It has no warnings or codeson the dash or that shows up on a computer. It used to do it occasionally but its getting pretty consistent now. I did do a forced regen and that didnt help. Anyone have any ideas or suggestions? Thanks
  3. sirjeff
    sirjeff Medium Load Member
    Check your exhaust clamps. Ill bet one is loose or a gasket is shot and it can't do a proper regen, so it keeps trying
    99kw900 Thanks this.
  4. North Pole Nightmare
    North Pole Nightmare Road Train Member
    1,013
    2,085
    Dec 15, 2021
    We had 50 T 880s with the 565 hp X 15,bumped up to 615 hp after they got 50,000 miles on them.Some of them would do that also,try to do the passive regen when stopped in traffic.Only last a few minutes.I don't know if they ever found a cause for it.We did get some bad def once in a while.
  5. 99kw900
    39
    186
    Feb 26, 2020
    We have 2 trucks filling out of the same def tank and the other truck isnt having any issues. I cant seem to find any exhaust leaks and I dont think the filter is getting plugged because when plugged into the computer the sensors arent showing a restriction.
  6. North Pole Nightmare
    1,013
    2,085
    Dec 15, 2021
    They had some seal problems on the top of the def tank,on quite a few of the trucks.def would get a little contamination through the bad seal.Def quality should be 32% if you can read it on your computer.
  7. rbrtwbstr
    rbrtwbstr Road Train Member
    3,401
    7,937
    Jul 11, 2012
    in the bush somewhere
    Just some food for thought, the truck I run doesn't have any emissions stuff on it. But last year the truck would randomly start idling at 1200 rpm. Turned out to be a bad alternator
    99kw900 and Oxbow Thank this.
  8. Oxbow
    Oxbow Road Train Member
    13,649
    141,469
    Nov 24, 2015
    That's interesting.
