X15 Cummins coolant problem
Discussion in 'Ask An Owner Operator' started by Rj8699, Aug 5, 2024.
  1. Rj8699
    Rj8699 Bobtail Member
    Hey guys in need of some help to see what is causing this issue. Have a 2019 W900 x15, deleted. Recently coolant light had came on for about a min, i checked it and coolant was right at the (minimum) didn’t think much of it. Following morning when checking the coolant level it was below the minimum line so added a little bit over minimum line. Later in the day coolant light had came on again and I checked it and it spilled out I believe it was from the overflow reservoir cap. Got to the yard and coolant was still at minimum. Went like for about 2 days and started doing the same thing and spilling out the cap. Ive also notice the coolant sizzling up/bubbles. Also still has a bit of pressure when opening up the coolant cap when left off over night.
  3. Crude Truckin'
    Crude Truckin' Alien Spacecraft
    2,456
    6,861
    Oct 22, 2016
    North Dakota, Eh?
    I’d do a combustion gas test on coolant. That’s where I’d start.
    Opendeckin and FloridaRetired Thank this.
  4. Blagoje
    Blagoje Medium Load Member
    441
    961
    Jul 14, 2022
    Paris, Illinois
    I have had two T680 trucks with the x-15 engine and both consume coolant more than any other engine I've seen. After driving for a day I usually need to add at least a half gallon of coolant. I consider the maximum fill line to be the minimum fill line in reality and even the guy at my shop usually overfills the reservoir knowing it will consume the extra coolant no matter what.
    I have ran into the issue that you are experiencing when it over consumes coolant while you're driving. If you remove the radiator reservoir fill cap after the coolant is warmed up it will depressurize the system and throw the sensors off to the point to where you could just fill the whole thing up completely and the low coolant warning indicator will still go off. Once you turn the truck off for the day and let it take some time to reset itself the next day everything should be fine.
  5. 77fib77
    77fib77 Road Train Member
    11,693
    77,232
    Jul 7, 2010
    St Louis
    Some places put vacuum on the system by using the radiator cap. They do it to suck out air pockets. I dint know how much that equipment costs but it's an idea.
  6. snowwy
    snowwy Road Train Member
    20,612
    13,333
    Jul 6, 2009
    Fill it to max line and see what happens. Not minimum.
    On another note. The last x15 i drove needed some type of seal in the pistons. What i was told anyways. But I was losing a gallon and day that eventually went up to 3 gallons a day.
    77fib77 Thanks this.
