X15 Cummins knocks under acceleration
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Brandon0928, Dec 3, 2022.
  1. Brandon0928
    Brandon0928 Light Load Member
    184
    105
    May 14, 2022
    2017 x15 knocks under acceleration .Loaded or empty. Gets noticeably worse when you get to 1500 rpm and around 63mph. At idle you can run it up to 1500 and doesn’t knock.
    2018 579 Peterbilt. Sounds like it’s coming from the valve train but hard to judge going down the road . What could it be ? Took it to 2 different places and they couldn’t find anything. Have noticed a slight turbo surge at idle last week. And the air intake makes a “popping” noise while compressor is running
    KB3MMX Thanks this.
  3. Brandon0928
    184
    105
    May 14, 2022
    Did injector rail test and that passed . Did cutout test. Passed . Truck still runs good with no power loss. Sometimes it feels like the knock can also produce a “shake”
    KB3MMX Thanks this.
  4. Brandon0928
    184
    105
    May 14, 2022
    I can be going 65 in 13th gear at 1300rpm with boost at 30 and barely hear it . Drop back to 12th going going 65 at 1550 rpm it knocks. The second you let off throttle it goes away
  5. Tropsnart
    Tropsnart Road Train Member
    1,130
    2,386
    Jun 8, 2015
    Pavilion New York
    I'd start with new fuel and air filters if it's not doing it unless it's under load. I had the same popping noise on my 2018 x15 from the air compressor. It sounded like garbage but never amounted to anything. I just made sure all the connections were tight and sampled the oil regularly.
  6. Brandon0928
    184
    105
    May 14, 2022
    did oil sample last week and came back good . New air filter . New fuel filter. Oil change
  7. runningman0661
    5,393
    16,373
    Mar 5, 2009
    Clover, South Carolina
    I have a 2018 X15 every year I have the shop run an overhead, two years ago they noticed cam lobe wear, but it was “within spec” 6 months ago during my annual overhead it had gotten progressively worse. So I replaced the cam and all the rockers. Cummins has had cam issues, not sure if this would cause the issue your having, but you should look into it.
    KB3MMX Thanks this.
  8. Short Fuse EOD
    2,798
    8,789
    Jul 29, 2015
    Midwest
    Have the same thing on a 22. Remounting the fuel pump, timing was off helped a little. Still have the issue. Same as you describe. 1500-1600 rpm heavy pull mostly in 17 gear. Cummins and Pete say don’t worry bout it. Gonna run till she blows and put in a 60 series more than likely.
  9. Brandon0928
    184
    105
    May 14, 2022
    So stack is covered in white. Missing a quart of antifreeze. Also noticed that the truck has the same shake while using engine brake. This is a bummer
    KB3MMX Thanks this.
  10. Bonzha
    Bonzha Bobtail Member
    4
    May 20, 2020
    Got the same problem. Did you resolve it?
    KB3MMX Thanks this.
  11. KB3MMX
    KB3MMX Road Train Member
    3,079
    2,596
    Dec 29, 2014
    Orrstown, PA
    Was it a bad EGR cooler ?
