X15 Efficiency with auto: cruise control
Discussion in 'International Forum' started by Tb0n3, Jan 31, 2019.
  1. Tb0n3
    Tb0n3 Road Train Member
    4,607
    9,254
    Oct 5, 2012
    Earth
    I'm getting pretty sick of this cruise because it'll try to coast to the speed on the slightest of inclines, leaving you driving 4mph below the speed limit for half an hour. Is this just the way they are for pure efficiency, or is there a problem with mine?
    Fuller Advantage 10 speed in a prostar
  3. Tb0n3
    4,607
    9,254
    Oct 5, 2012
    Earth
    I don't get it. Sometimes it'll climb a hill at 100% keeping at the set speed, but sometimes it'll run partial throttle and keep dropping speed while it's fully capable of maintaining.
    KB3MMX Thanks this.
  4. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    There's an easy way to fix it, don't use cruise and drive with your foot.
  5. stillwurkin
    stillwurkin Road Train Member
    1,756
    2,856
    Dec 2, 2017
    My dad always told me you have a left foot sitting there with nothing to do..use it. Old old school.
  6. stillwurkin
    1,756
    2,856
    Dec 2, 2017
    Meant right foot and left. My proof reading skills are diminishing.
  7. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    I've run the gas with my left foot, your right foot starts cramping a little use your left one for a bit, works ok as long you dont have too much for hills.
  8. Tb0n3
    4,607
    9,254
    Oct 5, 2012
    Earth
    I was perfectly fine with my 10 speed as I knew exactly what gear I was in and what speed what sound was so it kept my attention. Autos are like trying to watch paint dry. Not exactly entertaining.
  9. KB3MMX
    KB3MMX Road Train Member
    3,075
    2,595
    Dec 29, 2014
    Orrstown, PA
    This is a parameter setting called eco cruise or whatever.
    You can shut it off and it'll be normal cruise.... Your can control a ton of stuff in the parameters ...
  10. Tb0n3
    4,607
    9,254
    Oct 5, 2012
    Earth
    The company had full economy mode programmed, but scaled back on that. It's running much better, but far from perfect. I have a sample size of two, but both I and another driver are averaging 6.0mpg when a 10 speed got 6.2. They fell for the "automatics is better fuel economy" line.
  11. KB3MMX
    3,075
    2,595
    Dec 29, 2014
    Orrstown, PA
    Truck is only as good as the idiot behind the computer setting all the parameters lol.
    That truck should be getting 7+ with an auto haha..... Actually with the X15E it should be 8+ in an aero truck
