X15 stopping without engine brake on
Discussion in 'Trucks [ Eighteen Wheelers ]' started by L3v1s, Jan 4, 2023.
  1. L3v1s
    L3v1s Bobtail Member
    12
    Dec 8, 2014
    Hey guys, I've got a 2022 International HX520 with a X15 in it that does something very weird. Sometimes when I lift my foot of the throttle the turbo starts to whistle and slows down the truck without the jake brake being on. The jake brake has 3 levels with the first utilities 3 cylinders, second engages all 6 and the 3rd level is the added braking power of the variable geometry turbo. For some reason the 3rd level engages without the other 2 even though the jake is set to 0/off. This happens every time I stop the engine and start it again and it usually stops shortly after I get on the freeway.
    Added bonus to the situation is that since it has a ultrashift, once the turbo kicks in it drops a gear or 2 and completely stopps me in my tracks especially when empty.
    I've been to 4 different shops (3 International and 1 Cummins) and no one has ever heard of anything like that. One shop foreman even tried to convince me, that this is perfectly normal without being able to explain how is that normal. I've spoke with Cummins customer service and they've said they've never heard of that. The same answer I got from Eaton saying they only supply the transmission, but they're not responsible the gear dropping as the engine is the one that controls it in this situation.
    On a separate note, the transmission itself doesn't work very good as it does not differentiate between being bobtail on a level ground and a tail wind and pulling black mountain at 130k gross. It always changes gears at the same time with the same sequence. No matter how gentle I'll push the pedal it will not change gear before 1600rpm and it will always skip the same gears regardless of the weight or terrain. Eaton said it needs calibration, but even after it got calibrated, it still does the same thing. Any thoughts on this?
    Has anyone of you guys experienced or heard of such bizarre behavior be it in x15 or other engine/transmission?
    D.Tibbitt Thanks this.
  3. D.Tibbitt
    157,282
    I think I know what ur talking about with the turbo spooling when Let off the fuel pedal but Jake's aren't on. I noticed it on the 2020 kw I drove a couple years ago - I think I figured out it was doing a regen at the time which spools the turbo a small amount. That could be what ur hearing when u let off the pedal .
    cke and L3v1s Thank this.
  4. L3v1s
    12
    Dec 8, 2014
    Yes, when the truck enters into regen it really spools the turbo and pushes the rpm up, but it doesn't slow down the truck or at least doesn't do it noticeably. What I'm talking about is a situation in which the engine is actively trying to stop the truck from moving using the turbo as a jake brake while the jake brake is not active. When this happens you can either accelerate or slow down, there’s no middle ground.
  5. Short Fuse EOD
    2,791
    8,762
    Jul 29, 2015
    Midwest
    It’s the vgr turbo doing its job. Part of the emissions process. Feels as strong as level 3 Jake. Sucks when it does it on icy roads. If the truck didn’t have the emissions on it anymore, it will stop doing it. Had a hard time adjusting to it when I got my X15.
    Concorde, cke and D.Tibbitt Thank this.
  6. pushbroom
    pushbroom Road Train Member
    1,791
    7,403
    Sep 1, 2012
    It is to keep heat in the exhaust to meet emissions. Normal operation, cannot disable it.
  7. Heavyd
    Heavyd Road Train Member
    7,828
    6,277
    Feb 4, 2009
    Like mentioned, this is a normal thing and all trucks do do it. I know what you meant, I swear the engine brakes are on, but they aren't. As for the shifting, there are several shift strategies available that can be selected by someone with Eaton Service Ranger software to get a behaviour you like.
    D.Tibbitt, pushbroom and Goodysnap Thank this.
  8. Concorde
    Concorde Road Train Member
    5,500
    19,551
    Jun 29, 2016
    West Melbourne Florida
    Yep, my 2023 does it as did my 2021..Now I know why, thanks!
    Was always curious about it.
  9. BobbyD13
    BobbyD13 Bobtail Member
    25
    14
    Feb 10, 2017
    My truck does it i hate it. 2019 579 X15 with 12 speed auto
    Heavyd Thanks this.
