X15 vs DD16
Discussion in 'Ask An Owner Operator' started by Leftlanemilktrain, Aug 11, 2020.
  1. Leftlanemilktrain
    Leftlanemilktrain Bobtail Member
    13
    20
    Aug 4, 2020
    How does a X15 pull against a DD16 if anyone has run both? Also any major issues with either under 300k? Next thing is any noticeable differences between x15 565 and 605 in performance?
    singlescrewshaker and PoleCrusher Thank this.
  3. PoleCrusher
    PoleCrusher Road Train Member
    7,503
    82,194
    Aug 26, 2014
    LLMF
    Good question, I hope someone can answer. I do know everyone I've talked to with the performance X15 has said it's a great engine.
  4. uncleal13
    uncleal13 Road Train Member
    3,797
    6,300
    Apr 9, 2009
    Humboldt, Sk
    Don't know about performance. I have a DD16 it gets about 0.8 mpg better pulling 140,000 lbs than buddies International HX520 with 565 X15.
  5. Eggroll'n Trucker
    Eggroll'n Trucker Light Load Member
    213
    157
    Feb 17, 2018
    That must have something to do with the gearing ratio
    alds and Leftlanemilktrain Thank this.
  6. Carlinho
    Carlinho Bobtail Member
    28
    39
    Mar 2, 2018
    Harker Heights, Texas
    Maybe not that big of a difference but the number of places that will service and have Cummins parts far outperforms the amount that have Detroit and paccar parts.....that was my reasoning for getting a truck with a Cummins
    Leftlanemilktrain Thanks this.
  7. Leftlanemilktrain
    13
    20
    Aug 4, 2020
    I currently run a few isx's and am very happy with performance especially after the smoke detectors are eliminated. That being said my mechanic now parks his escalade where his ford ranger used to sit.. Are these newer engines holding together better?
    TexasKGB and blacklabel Thank this.
  8. uncleal13
    3,797
    6,300
    Apr 9, 2009
    Humboldt, Sk
    Both 18 speeds, 11R24.5 , 3.91 46,000 lbs rears.
    Maybe break in period, X15 is only 4 months old.
  9. Eggroll'n Trucker
    213
    157
    Feb 17, 2018
    That could be it! Also they both have different power curves. So if the driver shifts at a particular rpm that's maximizes power on one engine it may not have the same power curve at that rpm on the other engine.
    shawnhhllc Thanks this.
  10. Midwest Trucker
    5,919
    21,420
    Aug 31, 2018
    X15 all year long.
    Depends on how you have the computer specs setup far as power. The X15 has been very reliable.
  11. Cat sdp
    Cat sdp . .
    21,372
    76,828
    Apr 8, 2012
    Orion's Belt
    I thought they discontinued the DD16...?
    So unless your buying used you can’t get one anyways
