XM antenna on dash?
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by gkmissingca, Aug 13, 2019.
  1. gkmissingca
    gkmissingca Light Load Member
    102
    29
    Feb 18, 2017
    I work for CTI and change trucks like I change my socks. I have my XM radio connected to a bluetooth transmitter which can connect to the truck.
    Would the antenna work through the windshield?
  3. Diesel Dave
    9,653
    32,687
    Jan 20, 2010
    Hesperia, Ca.
    I use my XM on my phone thru the app. Run the Bluetooth or USB to the deck. No antenna needed.
  4. MrEd
    MrEd Road Train Member
    2,196
    2,836
    Sep 2, 2011
    Winfred, SD
    It will work on the dash when you are pointed the right direction. Otherwise, when the cab is blocking the signal it drops off fast.
    Dieselboss and gkmissingca Thank this.
  5. solitary_con
    solitary_con Light Load Member
    147
    137
    Mar 2, 2007
    Cook County, IL
    Depends on the area of the country you're in. Down south its works more time than not, Up north, it's going to be very intermittent.
  6. AModelCat
    164,644
    I got better satellite reception with my Sirius antenna sitting on the dash than my Chevy or Ford ever got with the factory satellite radio. Never hurts to try. I'm sure it'd work alright.
  7. Highroller58
    Highroller58 Bobtail Member
    16
    15
    Sep 18, 2016
    Mine didn't work too well on the dash mounted on the outside works much better
    Dieselboss Thanks this.
  8. Brucesmith
    Brucesmith Heavy Load Member
    736
    505
    Jun 16, 2012
    If you are slip seating just use electrical tape to attach the puck to your mirror arm Easy to remove and cheap! Works almost as good as a stick antenna
