Yellow Low Def light
Discussion in 'Freightliner Forum' started by danny23tx, Dec 7, 2019.
  1. danny23tx
    danny23tx Road Train Member
    1,494
    2,324
    Feb 16, 2016
    Austin,Tx
    The little yellow light that's warns def is low is stuck on . The Green bars that indicate def level are working , filled up Def and the Bars read full tank but little yellow light still on . Any one have this problem?
    D.Tibbitt Thanks this.
  3. D.Tibbitt
    156,674
    Is it throwing a code? My cascadia used to do that when i would idle alot . Never could find the problem
  4. danny23tx
    1,494
    2,324
    Feb 16, 2016
    Austin,Tx
    No codes whatsoever. Gauge works no issues other than the tiny light .
  5. Roberts450
    Roberts450 Road Train Member
    2,237
    3,638
    Feb 6, 2016
    How many key cycles have been made since it came on?? Did it get low enough to actually trigger it?
    Thinking it might clear on its own if it got ran low enough to come on but I dont know the FL/DD DEF system at all. My pete just had a red warning light on the gauge when it got below 1/8 of a tank but it would go out when filled above that level.
  6. danny23tx
    1,494
    2,324
    Feb 16, 2016
    Austin,Tx
    Yeah Def went low , I thought it would go away once filled. Probably the second time in 3 years it actually came on , I keep it filled most times . Might on plug Def tank and investigate once I make it home in a week.
  7. mhyn
    mhyn Road Train Member
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    subscribed.... lol
  8. danny23tx
    1,494
    2,324
    Feb 16, 2016
    Austin,Tx
    Any thoughts?
  9. mhyn
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    hook up the DL and check to see you had history fault codes related to aftertreatment that day/time. if not replace the gauge.
  10. danny23tx
    1,494
    2,324
    Feb 16, 2016
    Austin,Tx
    Cleared up today . Almost 2 months later lol .
  11. mhyn
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    it may come back again when weather will be hot...
