Yes, another question
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Cat nip, Jan 20, 2010.
  1. Cat nip
    Cat nip Light Load Member
    192
    10
    Jan 17, 2010
    Magnolia, TX
    My truck has a pyrometer, but no boost gauge. Is there a kit I can get and install? I''m sure there is, but what do you guys recommend?
  3. cumminswillie
    cumminswillie Bobtail Member
    8
    Jan 30, 2009
    richfield WI
    Check into teltek Guages out of nevada.
    Cat nip Thanks this.
  4. 379CAT
    379CAT Light Load Member
    114
    20
    Feb 10, 2009
    springdale wa
    i have tel tek pyro and air temp guages, you can buy them as a kit that come with everything you need to install them. i love mine and im sure they would not cost any more then factory guages
  5. lowbudget
    lowbudget Medium Load Member
    428
    110
    Apr 12, 2008
    Bismarck, ND
    Personally, I would like to install actual pressure gauge (0-50 psi), with a line run from the intake to the gauge. I think it would be more accurate and quicker responding than the voltage/magnetic gauges.
  6. Cat nip
    192
    10
    Jan 17, 2010
    Magnolia, TX
    Ok i have a manifold pressure gauge, is that a boost Gauge??? Just mounted on the intake instead of the turbo?
  7. Longhood379
    Longhood379 Medium Load Member
    389
    125
    Nov 30, 2009
    Cremona AB
    It should be, Under power an accert should show 55-65 psi
