Yoke input output orientation
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Dino soar, Sep 22, 2019.
  1. Dino soar
    Dino soar Road Train Member
    4,817
    27,071
    Dec 8, 2017
    I just wanted to double-check before I put the new yoke on the input shaft on my front rear.
    The orientation of the input yoke to the output yoke one should be horizontal and one should be vertical.
    This is the correct way to orient them?
    stayinback Thanks this.
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,562
    6,648
    Aug 26, 2014
    Those have no orientation just put it on.
    pushbroom, starmac, Dino soar and 2 others Thank this.
  4. stayinback
    stayinback Road Train Member
    3,911
    8,257
    Jan 24, 2014
    chicago,il
    Of Course..But make sure they are EXACT,for balance issues,Exact spline when you put yoke on in perpendicular orientation.
    And if you removed the Slip yoke,carrier bearing and dropped the whole shaft- I hope you marked everything- Just a slight offset will throw you into a huge vibration
  5. Dino soar
    4,817
    27,071
    Dec 8, 2017
    Actually everything just came back from the driveline shop. Everything is balanced and marked and I have everything new carrier bearing U-joints everything.
    I just wanted to make sure there isn't some way to orient that that will throw me out of balance.
  6. swaan
    swaan Road Train Member
    2,942
    4,376
    Jul 12, 2009
    BC canada
    Yolk goes on the spline on the input shaft any way you like. No orientation for that.
    spsauerland, starmac and Dino soar Thank this.
  7. AModelCat
    165,355
    Yep. Just put the yoke on the diff and call it a day. The input and output yokes on the front diff will never stay in the same orientation. They aren't on a solid thru-shaft, there's an interaxle differential between the 2 yokes.
    pushbroom and Dino soar Thank this.
  8. Animosus
    Animosus Heavy Load Member
    736
    2,936
    Dec 7, 2015
    SE Wyoming
    As ^ he said. Those yokes are connected through a differential, it doesn't matter how it's installed. They can turn at different speeds.
