Your dream engine?
Discussion in 'Ask An Owner Operator' started by petefan4000, Dec 1, 2021.
  1. petefan4000
    petefan4000 Light Load Member
    107
    129
    Dec 2, 2020
    If money and resources were no object, what would your perfect truck engine be? Doesn't have to be anything that is or was put in production. Anything you want.
    Mine would be a two-stroke, opposed-piston V12 engine. 60° V angle, 92 cubic inches per cylinder (91.6mm bore 114.5mm stroke per piston). Twin turbos and twin Roots blowers. Common rail fuel injection. And no emissions devices outside of DEF.
    Basically a heavily modernised, souped-up, opposed-piston 12V92.
  3. bad-luck
    bad-luck Road Train Member
    3,435
    6,324
    Nov 16, 2013
    Baltimore, Maryland
    Mine is simple, 1000hp that runs on air, never needs maintenance and runs forever.
  4. ProfessionalNoticer
    2,941
    7,858
    Apr 25, 2021
    Beat me to it lol!
  5. Dino soar
    Dino soar Road Train Member
    4,815
    27,071
    Dec 8, 2017
    I have it...
    The mighty Big Cam.
    If I found a woman half as good as that engine, and that simple to maintain...
    She'd still be 2nd to the Big Cam, lol.
  6. homeskillet
    homeskillet Road Train Member
    6,317
    48,882
    Jun 1, 2013
    Dayton, OH
    Mack Econodyne. Nearly bulletproof.
  7. Arctic_fox
    4,509
    25,470
    Sep 16, 2016
    Cat 3406 sans all the electronics and emissions #### but with the MPG of a modern engine.
  8. Big Road Skateboard
    7,096
    40,276
    May 2, 2021
    Just give me an old 60 Series. You guys wanting mechanical engines may have forgotten how big of an improvement electronic fuel injection was. Yes, they'd run till they ran out of fuel, but with complex injection pumps and 4 mpg.
    Early EFI systems were very simple, easy to diagnose, and offered fuel economy/horsepower with little effort
  9. roundhouse
    roundhouse Road Train Member
    3,213
    7,334
    Jul 11, 2018
    Yep
    I had a 1985 Ford LTL 9000
    With a warmed over big cam 400 and a 13 speed
    loved that thing
    also had a cabover international with the set back steer axle and the 350 big cam and a 13 speed
    liked it too
  10. JoeyJunk
    JoeyJunk Road Train Member
    8,762
    68,032
    Dec 31, 2010
    Washington, PA
    Well, being I need a rebuild now……a 12.7 Detroit that isn’t worn out lol. Not too much to ask right?
  11. petefan4000
    107
    129
    Dec 2, 2020
    I've started to wonder what an electronic retrofit pump would look like on a mechanical 3406. It would look the same on the outside as an A, B, or C model pump but without the governor on the rack. You'd have a socket for a plug, as the check valves would be electronically controlled through solenoids and an ECM instead of a rack, scrolls, and a governor.
