Your thoughts on a volvo?
Discussion in 'Ask An Owner Operator' started by warrior12345, Sep 4, 2018.
  1. warrior12345
    warrior12345 Light Load Member
    75
    41
    Jul 16, 2017
    Hello .
    I am thinking about buying a volvo d13 ishift with 500HP eco torque .i usually gross 76k on my loads .what do you guys think? Should i go for it or would that hurt my mpg since it is 500 hp.cuz i keep hearing that the 425hp is a good combonation with ishift .
    Does high HP hurt mpg?
    Thank you
  3. Have you driven a Volvo before?
  4. warrior12345
    75
    41
    Jul 16, 2017
    Yes i did drive many and i love the comfort and everything about a volvo .
  5. Does what your buying fit what your wanting to haul? Asking these guys a question you know the answer to seems redundant.
    More of the question would be
    What issues may I run into?
    Are parts easy to come by?
    What is the cost of Operating this Volvo?
    Go that route.
    Shock Therapy Thanks this.
  6. warrior12345
    75
    41
    Jul 16, 2017
    I appreciate your answer .i know the parts are expensive and most of the times only volvo dealers have them .but my question was mainly about the fuel mileage and whether the 500hp is a plus or bad thong on relationship with the Ishift .
    Thanks
  7. KillingTime
    KillingTime Road Train Member
    3,865
    61,879
    Mar 26, 2016
    Rockland, Maine
    There isn't a bad thong to be found unless you're on a Maine beach surrounded by Male Canadian tourists.
    In all seriousness, the truck is calibrated to shift itself at certain Tac points. Whether that be 455hp or 500hp it's been calibrated... The I-Shift has undergone years of R&D. It's, hands-down the best automated manual transmission. Screw Allison, and The Eaton-Fuller Advantage. Fuel Mileage vs. hp might be your actual question... but I'll leave that to someone more knowledgeable.
  8. sirjeff
    sirjeff Medium Load Member
    Higher hp driven right you wont burn a drop more fuel in fact you might save some.
    The I shift can take it, there are several models each with slightly different specs and torque ratings - paired safely with whatever engine.
    warrior12345 and justa_driver Thank this.
  9. justa_driver
    justa_driver Road Train Member
    1,105
    817
    Apr 2, 2014
    Tennessee
    This has always been my stance as well. The harder an engine works, the more fuel its going to burn. You drive a large horsepower engine right, youll be coasting more than you will be pulling. You do not have to keep your foot in it to get those results either, just ease along down the highway..
    CorsairFanboy and warrior12345 Thank this.
  10. Espressolane
    18,690
    117,154
    If the truck your interested in purchasing fits your operation, then that is the truck you should purchase.
    Inspection will be the deciding factor. Might be worth the cost to have a third party do this. Then you know what your getting into. Plus you can then use the info to negotiate price and or repairs.
    Doing_flatbed_nc and warrior12345 Thank this.
  11. Mauricio.5283
    Mauricio.5283 Bobtail Member
    45
    27
    Oct 20, 2017
    I have a the 425 manual and 500 I shift D13. The 500 is a little less fuel economy at 70mph but at 65 they are about the same. The 500 pulls good on the hills at 80K and I shift is the best automatic I have driven, forget about the rest, the I shift really thinks. With the 425 you can tell the difference at full load.
    As far as maintaining I am very proactive so I haven’t have any breakdowns (except a defective radiator) on the road (knock on wood lol) I even fitted tire pressure monitor, saved my butt couple of times for over or under pressure.
    A friend of mine has the same Volvo VNL780 with a cummins 400 and 13 speed and the fuel economy is about the same overall. He has driven the d13 500 ishift and loves it, wants it as his next truck.
    The price for tensioners and belts are about the same for the cummins (me and my friend use the same dealer) the volvo filters are more money over fleetguard but gives me peace of mind. I bought an aftermarket radiator and 2 months later started leaking 2500 miles away, since then only VOLVO. The ishift fluid and filter was a bit pricey for a transmission but it calls for 250K intervals, I can live with that.
    So far very happy with the d13’s and love the ishift, I will try getting the same package when getting more trucks.
