Zerk fitting replacement?
Discussion in 'Ask An Owner Operator' started by HalpinUout, Sep 4, 2017.
  1. HalpinUout
    HalpinUout Road Train Member
    7,074
    18,165
    Oct 2, 2011
    I greased my truck for the first time today and had 2 fittings that don't appear to be taking in grease... I watched a video online of a guy that took a torch and heated it... Is there any other way, or how easy are they to remove and replace with new fitting? Thanks
    jamespmack and 4mer trucker Thank this.
  3. Mark Kling
    Mark Kling Technology Contributor
    10,935
    4,216
    Sep 23, 2007
    Statesville, NC
    wrench and may be a little hard sometimes,,, if so get vice grips.
    Harbor Freight sells a assortment of zerk fittings.
    jamespmack, 77fib77 and HalpinUout Thank this.
  4. AModelCat
    164,974
    Is it just pumping the grease out the connection or does the gun pressure up and seize? Easiest thing to do is to remove the fitting and clean out whatever is behind it and install new fitting. If that doesn't work you could try some heat depending on what it is that won't take grease.
  5. HalpinUout
    7,074
    18,165
    Oct 2, 2011
    That's exactly it... makes the gun seize up.
    jamespmack Thanks this.
  6. stayinback
    stayinback Road Train Member
    3,911
    8,257
    Jan 24, 2014
    chicago,il
    What are you greasing making the gun seize? King pins? Front spring pins?
    jamespmack and HalpinUout Thank this.
  7. HalpinUout
    7,074
    18,165
    Oct 2, 2011
    Pittman arm and rear brake cam
  8. HalpinUout
    7,074
    18,165
    Oct 2, 2011
    Napa sells a tool that you put over the fitting and hit it with a hammer, kind of the a punch type deal... Supposed to clear it up or clean out the stoppage... They want $43... Seems getting a box of fittings from harbor freight as mention above would be a lot cheaper. ..
  9. stayinback
    3,911
    8,257
    Jan 24, 2014
    chicago,il
    Yeah..It happens- About a month ago I re-zerked #3 U-Joint- actually the Zerk Broke in 2. Used a Pick to get the broken piece outta the joint- It Happens.
  10. AModelCat
    164,974
    I would keep the heat away from any steering or axle parts. Cams would probably be fine as long as you don't torch any airlines or wiring near them (or melt the bushings).
  11. AModelCat
    164,974
    Can try and turn the steering wheel back and forth and try to grease it at different angles. Could try and chock wheels and try to grease the cam with brakes released too.
    This is one of the reasons I don't care for extended service intervals. Grease hardens over time and with exposure to heat, dust etc. Can cause things not to take grease if the grease gets too hard.
