01 Classic abs light
Discussion in 'Freightliner Forum' started by Rideandrepair, Oct 23, 2018.
  1. Rideandrepair
    17,575
    56,930
    Aug 8, 2015
    Anyone know the location of ecu diagnostic button for blink codes? If any
  3. blairandgretchen
    13,973
    76,845
    Dec 9, 2011
    South west Missouri
    Toggle switch by pedals, or at base of steering column?
    Online driver manual for that year?
    Rideandrepair Thanks this.
  4. Rideandrepair
    17,575
    56,930
    Aug 8, 2015
    Might help someone. Located under bunk behind passenger seat . Wabco Meritor switch for blink codes abs light on dash flashes code.
  5. Rideandrepair
    17,575
    56,930
    Aug 8, 2015
    Updeat -might help someone in future. Fixed trailer abs light w/ new power cord to ECU $75.00 Got it working. Light stayed on.Had 1 bad sensor wire. Replaced both sensors( first) and then both extension wires $160.00. Wabco website has good info on flash codes.Trailer wheel Codes are opposite each other depending on valve type. Truck- had to replace light itself on dash. Light stayed on. Used button under bunk. Replaced sensor right wheel. Still on . Found broken wire in rear harness to valve and sensors. Replaced rear harness $155.00. Code went away and replaced by right steer sensor gap too wide. Pushed sensor in . Light off. I broke sensor bracket on rear drive. Fragile aluminum. Two 7/8 bolts hold it on. Only $5.00 at Dealer. Bought an extra gonna change out other side w/ new sensor too as PM next brake job.
    QUALITYTRUCK Thanks this.
