#1 Diesel in Minnesota
Discussion in 'Experienced Truckers' Advice' started by shiftqueen, Jan 16, 2018.
  1. shiftqueen
    shiftqueen Bobtail Member
    I've never run Minnesota in the winter and I've been seeing #1 diesel for sale. Should I fill my tanks with it instead of #2? Is it better to buy #1 or to buy #2 and treat it? I read that Kwik Trip winterized diesel is good, but should I also treat it? If you were going to treat the Kwik Trip winterized diesel, at what temperature would you start treating it?
  3. STexan
    STexan Road Train Member
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    You'll be fine with northern/winter blend #2. If you park your truck for extended periods and the temps may go well below 0F, then #1 might be worthwhile if it's allowed by the company [if that's the case]
  4. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    If I bought fuel there I'd buy #2 and treat the heck out of it beginning at 32 degrees. I prefer wi and nd fuel during winter. Avoid biodiesel in the cold. Mn has some law mandating the use of biodiesel, which would be fine if they ratcheted up the % in the summer and lowered it way down in winter. Maybe they do I am not sure. I learned the hard way when I was a new driver in 2008. Never again.
    Canadian fuel for the win!
    AModelCat and Justrucking2 Thank this.
  5. Justrucking2
    Justrucking2 Road Train Member
    3,211
    4,295
    Sep 12, 2017
    Plymouth MI
    20 years ago I used #1 up there, half and half. Now, like was said, the new winterized stuff, #2 should be fine. But, I would recommend finding straight #2, not that bio diesel crap. If you are running that watered down garbage, I would throw in some #1.
  6. shiftqueen
    Thanks everyone, for your replies.
  7. mitmaks
    mitmaks Road Train Member
    2,586
    2,102
    May 16, 2014
    Bottle of Howes in each tank if using biodiesel blend in winter should prevent any problems.
  8. Justrucking2
    3,211
    4,295
    Sep 12, 2017
    Plymouth MI
    $$$$$ Why would anyone use that crap in their motors, the bio? It is high in water content, algae in tanks and then the injectors and other costly parts, like emissions. It is beyond me why anyone would subject their livelihood to this voodoo fuel.
  9. mitmaks
    2,586
    2,102
    May 16, 2014
    If its all that's available or if your company dictates which fuel to use, youll have to use it.
  10. Justrucking2
    3,211
    4,295
    Sep 12, 2017
    Plymouth MI
    Well, I own my truck, and will only use that crap as a last resort. And only in small amounts to get me to real fuel. Another reason to avoid fleet trucks when looking to purchase a truck, they all run this crap fuel. Pilot and Flying J load theirs down with this stuff. Thank God Mom and Pop fuel stops are still out here.
    And don't mind me, I'm into the beer. I did not mean to come across as a smart ***. ;-)
  11. bowhunter67
    bowhunter67 Light Load Member
    283
    549
    May 28, 2016
    rush city mn
    You can use #2 up here thats blended already but if its going to get below 0 put in powerserve in the white bottle thats what i do and l shut my truck off last weekend @-22 and it fired right up
    Oldironfan and Justrucking2 Thank this.
