'13 Cascadia Lights Flashing While Parked
Discussion in 'Freightliner Forum' started by FullBit, Dec 15, 2014.
  1. FullBit
    FullBit Bobtail Member
    Dec 15, 2014
    So my wife and I have had this truck for a few weeks now and whether its been going on in the past or just starting tonight idk, I am sitting up late in the driver seat browsing the web when all of a sudden I hear what sounds like my turn signal is on. I slide my curtain over to see if my foot maybe hit the signal stick and nope no turn signals are gojng off.
    About 30 minutes goes by amd it is still clicking. My wife is in the sleeper with the bunk heater running as well. I got out to use the restroom and noticed that my tail lights (on the cab) are flashing on and off about every 1-1.5 seconds. I do not have any idea why... my lights are off, my hazards are off and there is not even a key in the ignition. It is only the rear ligjts also, the front markers and headlights are not on/flashing at all. Anybody know why the truck might be doing this?
    Thanks in advance.
    blairandgretchen Thanks this.
  3. FuzzFace2
    FuzzFace2 Medium Load Member
    417
    138
    Jul 27, 2014
    Angier, N.C.
    First I have to say I do not know what it could be but maybe a little more info may help.
    You said just "cab" and not the trailer too right? Did you look at the back of the trailer to make sure?
    What type trailer ie: refer/dry van/flat and who makes it?
    I take it it has an ABS light out back and did you disconnect the elect. light plug from the trailer to see if the lights stopped blinking?
    Why all the questions about the trailer you ask I wonder if you are getting a back feed from it to the cab and why I asked about pulling the light plug.
    Next time if it happens see if you can find the breaker that is tripping to see what else is on that circuit so you can look into that for the back feed.
    Good luck
    Dave ----
  4. dieselfuelonly
    dieselfuelonly Road Train Member
    2,475
    5,086
    Nov 12, 2012
    Chapel Hill, NC
    Don't some of these new trucks flash the lights if the driver forgets the set the parking brake and shuts off the truck? Maybe it's something related to that.
  5. blairandgretchen
    14,029
    77,458
    Dec 9, 2011
    South west Missouri
    We had the same truck where the interior map lights above the driver could not be turned off - had to unhook the entire cluster till we returned to the shop.
    Several trucks started doing it. Turned out to be n ECM setting fault . . . .
    Wierd. Give it to the shop and see what they find - Good luck.
  6. simon999
    simon999 Light Load Member
    240
    95
    Feb 6, 2014
    could be flashing relay
  7. SOUGROUP
    SOUGROUP Bobtail Member
    13
    4
    Jun 23, 2018
    Got a good one for you guys with Cascadias ,this happen to one of my drivers on our 2012 cascadia ,driver went to shower an clean up ,truck was perfect ,came back and all lites flashing without the flasher been on also the cruise would not accelerate the engine ,well he went crazy trying to figure out till about 3 am and then gave up, at 5 am the Military truck next to him that park after he went to shower left , and all problems disappear !
    the driver called one of his body's that work at a frighteliner dealer and he told him about the same problem with a government truck inside the shop that made another truck go crazy,,SO IF ANY ONE OUT THERE HAVE THIS PROBLEM CHECK YOUR SURROUNDINGS FOR ANY TYPE OF GOVERNMENT TRUCKS .
    D.Tibbitt and QUALITYTRUCK Thank this.
  8. importvic
    importvic Bobtail Member
    27
    14
    Apr 22, 2013
    Have you or anyone else found the cause of this? I have a 2013 Cascadia too and it does this intermittently. Only difference is my trailer turn signal side lights & tail lights do it with my truck tail lights & also the trailer front corner amber lights flash with them too. When I turn on my hazards a different clicking sound happens under the dash compared to the clicking it makes with this odd behavior. Tia!
  9. Mike250rs
    Mike250rs Heavy Load Member
    881
    7,082
    Sep 24, 2019
    Raleigh, NC
    SAM cab module.
    Usually from a leaking windshield.
    QUALITYTRUCK Thanks this.
  10. QUALITYTRUCK
    1,819
    1,784
    Jun 14, 2009
    romulus,mi
    Because your description includes trailer light issues I would lean more towards a bad Sam chassis module as opposed to a Sam cab module. Same reason. Water. Take cover off and pull relays and fuses out. I bet you will see much corrosion.
    mhyn Thanks this.
  11. h112
    h112 Bobtail Member
    Jun 8, 2016
    The "Light Test" switch. You probably pressed it accidentally. I just went through the same thing,couldn't figure out what's going on. Somehow it stopped. Then happened again and I'm press buttons trying to see if anything wod change and found the Light test switch is that makes it flash Lights like that. Hope this helps
    mskitty76 Thanks this.
