13 speed splitter/speedometer relationship
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by GliderKitTrucker, Sep 22, 2021.
  1. GliderKitTrucker
    GliderKitTrucker Light Load Member
    50
    36
    Dec 28, 2019
    To all my mechanics, I just happened to notice because I bumped it with my leg but I have a 2000 Pete 379. If I’m sitting still with the truck idling and i flip the shifter into high range then move the spitter from direct to overdrive it will make the speedometer go from 0 to 85 and back to 0. Same when you move it back from overdrive to direct. It will also throw my ELOG into driving. Can some explain the relationship between this and what maybe can causing this.
  3. Big Road Skateboard
    7,098
    40,288
    May 2, 2021
    Grinding during range shifts? I'd think a pad missing off a hi/low synchronizer might spin it.
    Actually, a loose yoke nut is more likely, causing your pulse wheel to spin.
    Seen it kick out high idle before due to vibration.
  4. GliderKitTrucker
    50
    36
    Dec 28, 2019
    I’ll double check everything but I haven’t noticed anything out of the ordinary as far coming out of gear/grinding or anything like that
  5. blairandgretchen
    13,933
    76,591
    Dec 9, 2011
    South west Missouri
    Like the doctor said.
    “Well, don’t do that “
    JoeyJunk Thanks this.
  6. GliderKitTrucker
    50
    36
    Dec 28, 2019
    Hahahaha.. yeah let me just make a note to myself
    blairandgretchen and Bean Jr. Thank this.
  7. BoxCarKidd
    BoxCarKidd Road Train Member
    4,548
    6,641
    Aug 26, 2014
    Speedometer works off a sensor counting cogs on the output shaft when they go by. The gear teeth in modern transmissions are cut at an angle. When you split or change ranges that causes the shafts to turn a little and probably rebound at the end. The cog moving back and forth at the sensor causes the reading which is normal.
    blairandgretchen and spsauerland Thank this.
