14 cascadia keeps shuting down on road
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 77fib77, May 31, 2022.
  1. 77fib77
    77fib77 Road Train Member
    11,701
    77,329
    Jul 7, 2010
    St Louis
    I have a 14 cascadia, dd15, 555k miles. Sometimes it shuts down over bumps some times it doesn't. I have changed ignition switch, master power switch. I have checked alternator, starter, battery box cables.
    I have been told by one mechanic that he won't know what is wrong until it stops working. I don't like this answer. He hooked up the computer and didn't find any codes.
    I'm not sure what else to look for. What are the run wires out of the ignition switch? Is there a master power cable to the ecm?
    My truck exhaust has been modified otherwise I would go to the dealership.
    Out of the ignition switch, which wires are the run wires?
  3. Judge
    92,556
  4. 77fib77
    11,701
    77,329
    Jul 7, 2010
    St Louis
  5. Judge
    92,556
    Power net distribution module
    77fib77 and Oxbow Thank this.
  6. Judge
    92,556
    I had to change mine out, 16 cascadia, started around 590k ran it til 615k before i found that video.
    Fixed my troubles.
    baha, 77fib77 and Oxbow Thank this.
  7. 77fib77
    11,701
    77,329
    Jul 7, 2010
    St Louis
    Mine only does it over bumps. Was yours the same?
    I'll change it anyway. Thanks for the quick response. It's a little un-nerving.
  8. Judge
    92,556
    mine would, sometimes a small bump.
    it’d die, go through system, sometimes stop again as if you killed it again,
    you could cycle the key, but it wouldn’t matter and start it again
    77fib77 Thanks this.
  9. Freightliner22
    Freightliner22 Bobtail Member
    17
    32
    Apr 22, 2022
    Athens tn
  10. Freightliner22
    17
    32
    Apr 22, 2022
    Athens tn
    I had my truck dying and ignition going off on bumps, my battery disconnect switch was doing that. Easy way of eliminating the switch would be to disconnect wire going to it and and see if the problem still there
  11. 77fib77
    11,701
    77,329
    Jul 7, 2010
    St Louis
    Just unplug it?
