14hr violation due to split sleeper
Discussion in 'ELD Forum | Questions, Answers and Reviews' started by Sixela918, Aug 26, 2023.
  1. Sixela918
    Sixela918 Light Load Member
    257
    397
    Nov 24, 2021
    Phoenix, AZ
    Samsara eld - I used the split sleeper option the other because the it gave me the option. Never ran out of time on the 14 hour. Got done for the day and did a reset (48hr), now it shows a violation of the 14 hr clock. But when I go to roadside inspection mode it doesn't show any violation. Am I correct in thinking that as long as the inspection mode doesn't show a violation, I'm fine?
    Stringb8n Thanks this.
  3. ZVar
    ZVar Road Train Member
    10,911
    23,833
    Sep 10, 2010
    Flint, MI
    It depends. It's probably in violation because it's not seeing a 7 hour sleeper berth.
    If you show your logs for that day and the next we can answer.
    It also could be a bug in Samsura since you selected spit it's expecting a 7 hour sleeper, even if it's not required because you never went over your 14.
  4. Movingismylifeilovemoving
    Movingismylifeilovemoving Light Load Member
    230
    292
    Aug 5, 2015
    Yes. It because you didn't show sleeper.
    If you stop your 14 hour clock with a 2 or 3 hour break you must show a 7 or 8 hour sleeper period.
    Just edit a portion of your reset to sleeper and the violation will go away
  5. Judge
    92,480
    Same thing on motive/KT always gotta show SB
    Albertaflatbed, Coffey and lual Thank this.
  6. Movingismylifeilovemoving
    230
    292
    Aug 5, 2015
    I think the law just changed in the past few months
    lual Thanks this.
  7. lual
    lual Road Train Member
    5,355
    9,785
    Oct 22, 2020
    SW Georgia
    From what -- to what?
    -- L
    Bean Jr. and Coffey Thank this.
  8. Cattleman84
    Cattleman84 Road Train Member
    10,028
    71,631
    Nov 1, 2017
    The Sticks, Idaho
    Inspection,mode should NEVER show violations... The inspecting officer is suposed to have to FIND a violation... Not have a computer point them out to him.
    Hammer166, BobO1176, lual and 6 others Thank this.
  9. Movingismylifeilovemoving
    230
    292
    Aug 5, 2015
    I looked for it but didn't find it...
    All I know for sure is samsara started showing that violation a few months ago. I was so confused at first
    Coffey Thanks this.
  10. Lyle H
    Lyle H Road Train Member
    1,292
    2,942
    Apr 16, 2014
    Are you Canadian?
    I don’t know their rules but if you are using USA guidelines if you did not exceed your 14 (you said you didn’t), even if you did use a split sleeper exception, you don’t need to show sleeper berth for the larger period of the two.
    The key here is that he never exceeded the 14 hour period in the first place.
    BUT….. if he did exceed the NORMAL 14 hour period, then yes he must show sleeper berth for a minimum of 7 or 8 hours whichever is needed.
    ZVar Thanks this.
  11. LUNDRYJEFF
    LUNDRYJEFF Bobtail Member
    19
    Aug 26, 2023
    THE ONLY DIFFERENCE IN INSPECTION IS A BLACK LINE OR A GREEN LINE BUT STILL SHOWES A ORANGE VIOLATION ICON
