1995 Peterbilt 379 Blinker Problems
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Asanchez, Mar 30, 2026.
  1. Asanchez
    Asanchez Bobtail Member
    37
    29
    May 17, 2020
    Have a 1995 Peterbilt 379 that has been having blinker problems. Mainly the passenger side blinker will not work. Replaced blinker relay and fuse which both burned. Tried new turn signal switch but still did not solve the problem. I unhooked the trailer plug but did not solve the problem.
    If I take a test light and touch any hot no matter the hood, turn signal switch, trailer plug or the rear blinker power wire the blinkers will blink
    blairandgretchen Thanks this.
  3. Tall Mike
    Tall Mike Road Train Member
    7,789
    37,881
    Aug 20, 2014
    New York State
  4. wore out
    wore out Numbered Classic
    17,461
    217,724
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Look behind the fuse box they are sorta bad to corrode
  5. blairandgretchen
    13,998
    77,103
    Dec 9, 2011
    South west Missouri
    Touching the test light would be providing a ground , so . . . wait.
    Any LED’s or a mis match of LED and incandescent bulbs in the flasher circuit?
    I had a problem right side only, wound up being chafed power to rear aftermarket mud flap light bracket.
    Check any non factory wiring first.
  6. Asanchez
    37
    29
    May 17, 2020
    All lights are LED. Been crawling all over the truck will check all the non factory again. Thank you
    Tall Mike and blairandgretchen Thank this.
  7. wore out
    17,461
    217,724
    Jun 5, 2013
    If they are all led even if you have the special LED flasher try putting 1 regular light in it somewhere. Especially if you were using a non LED test light.
    I’ve got 3 of those trucks. My favorite one your gonna have 1 non led light in the blinker circuit somewhere or they ain’t gonna flash
    W923, FLHT, Asanchez and 3 others Thank this.
  8. blairandgretchen
    13,998
    77,103
    Dec 9, 2011
    South west Missouri
    If you’ve got the rear light boxes - mudflap holders and center pieces, pull all that wiring out and check for a chafe.
    Is it an intermittent problem?
    Big Road Skateboard and Tall Mike Thank this.
  9. Asanchez
    37
    29
    May 17, 2020
    Started Friday put new relay with ground wire and still no right blinker. They work with the 4 ways
  10. Asanchez
    37
    29
    May 17, 2020
    I’ll go grab a regular light today thank you
  11. Asanchez
    37
    29
    May 17, 2020
    Update looked all over the truck and can not find a broken or chafed wire
