1995 Peterbilt 379 Blinker Problems
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Asanchez, Mar 30, 2026.
  1. JB7
    JB7 Road Train Member
    1,050
    1,862
    Dec 13, 2022
    Laurel, MD
    Should be a ground wire coming from the headlights and turn signal that is attached to the frame. Check and clean the ground wire.
    Asanchez Thanks this.
  3. Lowboy456
    Lowboy456 Medium Load Member
    301
    147
    Mar 14, 2017
    I found a similar issue once where a wire had worn through and would blow fuses pretty regular. It was under the steering wheel at the 1st steering knuckle inside the plastic cowling at your knee's when driving.
    blairandgretchen, Luwi67 and Asanchez Thank this.
  4. lester
    2,957
    8,088
    Jan 2, 2012
    NW, Iowa
    Did you just install all the LED lights and now it doesn't work or did it work previously with all the LED lights?
    Big Road Skateboard Thanks this.
  5. Asanchez
    Asanchez Bobtail Member
    37
    29
    May 17, 2020
    Truck has always had led lights since I started running it
  6. Asanchez
    37
    29
    May 17, 2020
    Found the problem was the right turn signal indicator in the dash causing a short
  7. Luwi67
    Luwi67 Heavy Load Member
    752
    485
    Oct 24, 2012
    Long island
    Same here but, with the city horn wire.
  8. Lowboy456
    301
    147
    Mar 14, 2017
    Was that a wire shorted or like a circuit board short?
    Not much is more aggravating than losing turn signals over and over.
    I turn all the lights on every morning and the emergency flashers and do a walk around.
  9. blairandgretchen
    13,998
    77,103
    Dec 9, 2011
    South west Missouri
    That is a new one - I know the CEL/SEL etc lights are the little blade bulbs in a twist lock - are the turn signal lights those too, and how was it shorted?
  10. Asanchez
    37
    29
    May 17, 2020
    I do the same checking myself. The light bulb was corroded at the bottom
    Tall Mike Thanks this.
  11. Asanchez
    37
    29
    May 17, 2020
    It was the little bulb in the twist lock was corroded at the bottom pulled it out of the dash and decided to put a new one and the blinker started working. Apparently they are bigger part of the system then I thought
