1996 Freightliner - Intermittent Engine Shutdown Light
Discussion in 'Freightliner Forum' started by Chodove, Feb 24, 2015.
  1. Chodove
    Chodove Bobtail Member
    4
    Hi all. We have a 1996 Freightliner with a Cat 3406E engine. Intermittently, the Shutdown Engine light on the dash will start to flash. Sometimes it will flash a few times and quit, sometimes it will continue flashing and then shut down the engine. If the truck is in motion, shutting off the key for a second or two and turning it back on will stop the flashing - sometimes for an indefinite period, sometimes for only a half a minute.
    We hooked up one of those diagnostic tools and it can't find anything wrong. We had the same problem last fall and the tool told us to change the rad fluid level sensor. We changed it and the truck ran well until today. We topped up the anti-freeze and tried messing with a bunch of wires, cleaning connections and such to no avail ...
    Does anyone here have a similar experience and a suggestion for a fix? Or even a suggestion for a fix without having had the same experience?
    Any help appreciated.
    Thanks
    Chodove
  3. fargonaz
    fargonaz Road Train Member
    1,167
    4,583
    Feb 9, 2015
    Mesa, AZ
    Does it do it with the cruise on? off?
  4. Chodove
    4
    It doesn't appear to be related to the cruise as it does it with the cruise switch on and with it off. Thx
  5. BoxCarKidd
    BoxCarKidd Road Train Member
    4,560
    6,646
    Aug 26, 2014
    Had a Western Star 3406E do that, it never logged any codes. It would cut on and off while driving or totally shut down. Might start right back up or after filters, priming, either, ETC. Could run an hour, day, or a week. Drove it full time with a reader and found when it cut out low oil PSI showed on scanner but manual gauge PSI was good. Oil sender fixed it but it never logged a code.
    Chodove Thanks this.
  6. xsetra
    xsetra Road Train Member
    5,199
    7,151
    Aug 21, 2011
    I had a similar problem with the cat in a White/Volvo/GMC? I had the EMC programed to not shut the engine off. Mine would flash the red light and shut off after 15 seconds. Moving or not. Nothing was ever wrong except for the warning light and the engine shut off. I changed several sensors without resolving the issue. Good luck.
  7. Chodove
    4
    Thanks for the info folks ... Will be taking a look at some grounds tomorrow and will definitely talk to the "real" mechanic to pass along suggestions. We are rather old school and this electronic gadgetry is a bit overwhelming to troubleshoot at times. The oil sending unit makes sense because I've noticed the gauge drop pressure for no reason, at any rpm high or low. Makes a lot of sense to me.
    I will let you know how we make out. This seems like a cool site. Thanks again for the pointers. :)
  8. Judge
    92,976
    Had the same kind of problem with a Volvo with a detroit, ended up being a sensor on the firewall telling the computer the truck was upside down and cutting the fuel off to the truck, but didn't give any codes but would do the same thing.
  9. Taylor1969
    Taylor1969 Bobtail Member
    Dec 27, 2021
    I Need help I Have A 1999 Freightliner Fld 120 Detroit 60 series truck and all of my warning lights have started to Come on. And then it will go off. But now evey now and then it shut off one time. All over my levels on oil, antifreeze and battery voltage is good. Can anyone tell me what might be the problem.. Thanks
    Rideandrepair Thanks this.
  10. Rideandrepair
    17,578
    56,942
    Aug 8, 2015
    First place to check is the battery to frame ground wires near the battery box. Also check the small positive wire with the 5 amp fuse in it. Make sure everything’s cleaned up, and tight.
    BoxCarKidd and AModelCat Thank this.
  11. AModelCat
    165,192
    Definitely sounds like a power/ground issue, making the system reboot.
