1999 Freightliner New clutch installed, problems.
Discussion in 'Ask An Owner Operator' started by RepoweredRookie, Aug 6, 2023.
  1. RepoweredRookie
    RepoweredRookie Light Load Member
    158
    134
    Apr 16, 2019
    Hey Guys,
    I have a 1999 Freightliner S60 12.7 with Rockwell Meritor trans. I just got a new clutch installed and now:
    1). it’s hard to get into reverse
    2). have to push pedal to the floor to upshift
    3). has 3 inches of freeplay
    4). mechanic says it’s normal and needs adjustment after 500-1000 miles
    I wanted to ask you guys if the above is normal on a new clutch before I take it back to have the mechanic look at it. Mechanic has already been kinda hard to work with. Appreciate any responses.
  3. Big Road Skateboard
    7,220
    41,025
    May 2, 2021
    Is it grinding trying to go into gear? The clutch needs to be adjusted to 1/2"-9/16" between clutch brake and TO bearing, then free play set to 1.5-2".
    3" is too much. Sounds like your mechanic probably put the clutch in and set the clutch adjustment, but not the free play, which leaves you without enough travel in the clutch to hit the clutch brake.
    FWIW, I put my clutch and trans in around 50 or 60k miles ago, and it hasn't changed.
    RubyEagle, 77fib77, mitmaks and 4 others Thank this.
  4. 201
    201 Road Train Member
    12,826
    26,411
    Apr 16, 2014
    high plains colorado
    No, that's not normal, and a new clutch should be just that, like new. The only reason you are able to shift at all, is on the floor, you are bumping the clutch brake. 3 inches of play is way too much and unsettling some bozo told you it was normal. Clutches don't have to be "broken in", and get it adjusted right soon. Who knows, the clutch guy maladjusted it on purpose to get you for a transmission later. Hey, don't think so?
    RepoweredRookie and Rideandrepair Thank this.
  5. abyliks
    abyliks Road Train Member
    4,154
    9,792
    May 2, 2010
    ludlow MA
    Needs to be properly adjusted, although I don’t know why you are using the clutch to shift to begin with
  6. Judge
    92,807
    Had a clutch put in KW almost 90k ago, still not been adjusted, doesn’t need it.
  7. Rideandrepair
    17,576
    56,941
    Aug 8, 2015
    He over adjusted it. Needs to be backed off. Properly adjusted as Skateboard said. First the 1/2” gap, then linkage if needed to get 1/8” gap at forks. 1/8” equals 1.5-2” freeplay. Clutch brake should also be checked for proper operation. Probably better off taking it somewhere else. Hopefully he did the installation correctly. Time will tell. Once properly adjusted it should work fine.
    RepoweredRookie and Last Call Thank this.
  8. Judge
    92,807
    If he shortcut that, might wanna make sure he put bolts on top back in the bell housing.
    Had one guy years ago screw that up and cost me a clutch and transmission, worked great, until one day it didn’t, Almosr needed a tow, but found a shop near i had to cripple it to.
    New trans and clutch and bell housing.
  9. RepoweredRookie
    158
    134
    Apr 16, 2019
    Yeah it grinds when going into gears and reverse. I’m going to pull the inspection plate, put a stick on the pedal and check the gaps. Thanks for the response Skateboard!
    Rideandrepair and 77fib77 Thank this.
  10. RepoweredRookie
    158
    134
    Apr 16, 2019
    I have tried many times floating with this Rockwell-Meritor trans, and it just won’t do it. I think the European trucks may be the same way.
  11. RepoweredRookie
    158
    134
    Apr 16, 2019
    That sucks, sorry you jad to deal with that mess. The bellhousing bolts were the 1st thing I checked after leaks and damage.
    Judge Thanks this.
