2000 379 fuse problem
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Soon2BeOwnerOperator, Apr 20, 2024.
  1. Soon2BeOwnerOperator
    Soon2BeOwnerOperator Light Load Member
    102
    51
    Feb 13, 2019
    New Hampshire
    Looking at a 2000 pete 379 12.7l to purchase. The blower won't work along with most internal electronics. Fuel, oil pressure guages work but no other gauges work. Blinkers and headlights work. Engine runs and truck drivers nice.
    It seems it is fuse board that got wet or corroded which is a common problem on these. How hard and how much you think this will cost to fix? I got one quote for 4-5 grand without the mechanic being able to see just rough estimate.
    Can I get a used part and repair this myself?
    blairandgretchen Thanks this.
  3. Ridgeline
    22,771
    124,455
    Sounds like more than just a fuse box issue, hope it is cheap because it can be a nightmare to fix.
    Grounds or lack of can also be a major problem.
  4. Nine_Lives
    Nine_Lives Bobtail Member
    22
    20
    Apr 20, 2024
    Did you check the big relay behind the dash/tach? If the cab leaks that relay sits under the firewall and wiper linkage just enough to fill with water and rust out. I'd check that first
    Deere hunter and blairandgretchen Thank this.
  5. AModelCat
    165,337
    I'd walk away and find something that doesn't have $5k worth of known issues. A 24 year old truck will usually have a lot more problems than that.
    Deere hunter, BoxCarKidd and Luwi67 Thank this.
  6. FLHT
    FLHT Road Train Member
    1,447
    2,622
    Aug 2, 2014
    I would RUN away as fast as possible.
    Leaking cab marker lights and windshield drain right into major electrical behind dash.
    I will bet the fuse box back side is corroded and needs complete replacement $$
    BoxCarKidd and AModelCat Thank this.
  7. blairandgretchen
    14,015
    77,307
    Dec 9, 2011
    South west Missouri
    Likely the accessory power relay, behind the “A” panel , where pyrometer and cigarette box is.
    wore out and Deere hunter Thank this.
  8. BoxCarKidd
    BoxCarKidd Road Train Member
    4,561
    6,647
    Aug 26, 2014
    I like your reply but will share this. If it was easy would they not have already fixed this. Worked with companies that payed me to inspect used trucks to purchase. One bought a group of used Volvo's. One of those Volvo White GMC tagged trucks had a temp gauge problem. Blew that off as everything else about this truck was awesome. That truck turned into being an electrical nightmare over the years.
    Maybe he can buy that and come out with a super deal. Maybe swap that relay and see that fixed the problem before you by it.
  9. Nine_Lives
    22
    20
    Apr 20, 2024
    Electrical gremlins can either be stupid simple or a living hell, two seconds with a test light and a jumper wire would tell the whole story of this particular case.
    Water never worries me in electrical and the wiring in these old trucks is good. The remnant signs of a door swinger with a pair of dykes and too much time would merit running away.
  10. Deere hunter
    2,183
    10,694
    Aug 5, 2017
    Shallowater Texas
    I've owned many of these trucks and it is always the relay behind the left panel behind your steering wheel and it's easy to fix
  11. Nine_Lives
    22
    20
    Apr 20, 2024
    And if you're having trouble figuring out where the water is coming from or you like preventative insurance take that new shiny relay, permatex the holes in the top of it and CAREFULLY drill a vent hole in the bottom... This will help keep the water out and let it drain if it happens to get wet again. Those are not cheap new and they'll last maybe a couple days if you're still fighting water.
    FLHT Thanks this.
