2001 FLD starting issues.
Discussion in 'Freightliner Forum' started by lciambotti1, Aug 3, 2020.
  1. lciambotti1
    lciambotti1 Light Load Member
    101
    16
    Mar 6, 2015
    Ok. Started out with what I thought was a bad starter, getting the clicking from the relay and solenoid. Replaced the starter, not fixed, replaced relay, starter button, batteries and alternator. Still not fixed. Any thoughts?? I am at a loss.
    Trucking Jobs in 30 seconds
  3. Rideandrepair
    7,469
    13,147
    Aug 8, 2015
    Did you clean all the cable connections? How about the Big ground to frame?
    Dino soar and baha Thank this.
  4. xsetra
    xsetra Road Train Member
    3,853
    3,932
    Aug 21, 2011
    Is the clicking noise coming from the starter or from the solenoid mounted on the firewall. Sitting in drivers seat it can be hard to distinguish between the two.
    Solenoid on firewall is mounted by the wiper motor above the steering wheel shaft.
    Good luck
    Rideandrepair and Dino soar Thank this.
  5. baha
    baha Road Train Member
    3,454
    1,978
    Jul 25, 2013
    ga
    X3etra is right the sol. is under a lot of wires and when you clear out the wires and find the starter sol. on the firewall its just 2 bolts and 2 wires that must be unbolted from sol. before you take the sol. off the firewall? Their is a ground cable from the eng. to the frame on the pass. side on some year trucks, but clean the large ground cable from the batt. to the frame near the batt. box.
    Dino soar and Rideandrepair Thank this.
  6. Rideandrepair
    7,469
    13,147
    Aug 8, 2015
    He said he replaced the selinoid already. Chances are one of the wires is broken, inside the insulation, at the eyelet. I’ve seen it often. Mine did that. I replaced the ends with good heavy eyelets, crimped, soldered, Heat shrinked liquid taped, and shrink wrapped it all again with a sleeve. Now it’s very heavy duty. Should never corrode again.
    Dino soar Thanks this.
  7. RocketyMan
    RocketyMan Medium Load Member
    354
    175
    Jun 5, 2015
    If you are questioning the wiring, I can look that up for you. Need last 6 of your vin.
  8. lciambotti1
    101
    16
    Mar 6, 2015
  9. Rideandrepair
    7,469
    13,147
    Aug 8, 2015
    Does the dash warning lights come on the top bar,on the dash with key on? Check engine, Etc.
  10. xsetra
    3,853
    3,932
    Aug 21, 2011
    Solenoid on firewall(magnetic switch)
    IMG_20200803_125835241.jpg IMG_20200803_125851063.jpg []
    The old firewall solenoid was more rectangular body. New one is round.
    Rideandrepair Thanks this.
  • Draft saved Draft deleted
