2011 prostar traction control light
Discussion in 'International Forum' started by shawn_ca, Aug 18, 2015.
  1. shawn_ca
    shawn_ca Light Load Member
    126
    14
    Jun 21, 2012
    Los Angeles, CA
    If anyone can help would be highly appreciated on this issue we are having with our truck. Just bought a truck about a month ago and now Traction Control light shows up and Electrical fault is in the message in the dashboard. It has been at international shop for 10 days they fixed some sensors but after a day same problem , no-none seems to figure this issue out. While driving some of the light to the trailer stops working signal and emergency signal lights , also all the controls on the steering (cruise,jake, horn) dont' work when traction light is on . some of the gauges on the right side of the dash dies . There seems to be some kind of electrical problem . anyone has had this happen t them ?
  3. realdesertkickin
    realdesertkickin Heavy Load Member
    925
    753
    Nov 18, 2013
    Tustoned Arizona
    Geez man, lemon law truck?
    I hear similar stories about internatl's shop...All the guys here in Tucson drive 2 hours to Phoenix for thier shop to avoid tucsons shop..
    My pal had a similar problem, he had wires fryed together right where the loom goes thru the firewall, caused abunch of wierdness..took awhile to find that one...It came down to an old schooler with a test light, wire ba wire
    lots of character Thanks this.
  4. supersnackbar
    20,302
    54,095
    Aug 19, 2007
    Your Town, USA
    I agree, sounds like bad wiring somewhere, and I wouldn't take it far because those blinking dash lights could turn into a roadside truck-b-q and then the only blinking lights you'll see are the ones on the fire truck that shows up to put it out.
  5. Heavyd
    Heavyd Road Train Member
    7,831
    6,282
    Feb 4, 2009
    Sounds like the body controller is getting mixed signals. I would be looking at the wiring between the steering column and body controller. The wiring from the steering wheel likes to cut through and short out on the steering column next to the tilt mechanism.
  6. AModelCat
    165,670
    Sometimes a roadside truck-b-q is the best thing that could happen to some trucks. Just make sure its insured first.
  7. KinetickQuantum
    KinetickQuantum Bobtail Member
    You might have to check steering wheel position sensor. It sits behind the steering wheel. It was the case with my truck.
  8. InTooDeep
    4,981
    37,364
    Jan 17, 2016
    Carmichael CA
    Hope he already has this fixed 6 years would be a hell of a long time to look at a light. But appreciate you trying to help a brother out
    Heavyd and QUALITYTRUCK Thank this.
