2013 KW T660 light module location
Discussion in 'Trucks [ Eighteen Wheelers ]' started by mitmaks, Feb 12, 2023.
  1. mitmaks
    mitmaks Road Train Member
    2,586
    2,102
    May 16, 2014
    Anyone know where light control module is on these trucks?
  3. pavrom
    pavrom Road Train Member
    3,217
    7,416
    Apr 29, 2012
    NE illinois
    What kind of problem you have ?!
  4. mitmaks
    2,586
    2,102
    May 16, 2014
    My front turn signals don't work inside headlights. All other lights work but turn signals.
  5. pavrom
    3,217
    7,416
    Apr 29, 2012
    NE illinois
    Fuse , relay , switch itself
  6. mitmaks
    2,586
    2,102
    May 16, 2014
    It must be problem with control module as everything else checks out
  7. bjytech
    bjytech Light Load Member
    246
    222
    Nov 9, 2013
    Had quite a few issues inside those headlight housings. the chassis node that runs all the lights will either be mounted from the top of the frame under drivers door or inside frame under/behind bunk.
    mitmaks Thanks this.
  8. mitmaks
    2,586
    2,102
    May 16, 2014
    Lights themselves are bad?
