2015 VNL780 Starting issues
Discussion in 'Volvo Forum' started by Lorne780, Mar 23, 2016.
  1. Lorne780
    Lorne780 Bobtail Member
    7
    Mar 23, 2016
    2015 VNL780 D13 Ishift 180,000 miles has intermittent starting issues, when you turn the key nothing happens. Truck goes through it's normal pre start routine fine and then nothing, sometimes after 10-15 attempts it will start other times you have to jump the solenoid. Starter and solenoid are new, batteries, fuses, relays and wiring all check out good and no codes not even when it won't start, Any Thoughts. Thx.
    Farah2017 Thanks this.
  3. boneebone
    boneebone Road Train Member
    2,297
    2,372
    Mar 13, 2009
    It could be the beginning of a faulty ignition switch.
  4. swaan
    swaan Road Train Member
    2,942
    4,376
    Jul 12, 2009
    BC canada
    Posibly a neutral safety switch on trans going faulty
    Damit just noticed it's an Ishift.
    Mmmmmmm
    Not to familiar with thous but not to rule it out either.
  5. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    Was a rebuilt starter put on when starter was replaced, many overseas rebuilds are bad.
  6. Lorne780
    7
    Mar 23, 2016
    Starter/solenoid were new put on by volvo under warranty
  7. countryboynance
    countryboynance Bobtail Member
    Mar 7, 2016
    Does it show neutral secure not detected on the dash when this happens?
  8. S M D
    S M D Road Train Member
    2,396
    3,406
    Mar 15, 2012
    sacramento ca
    Those new parts put on are just referbushed parts. Im going to say either the wires got loose over time and it cant fire. Or the parts went bad. I would check the wires if that doesnt work id replace it. And take care of that possibility
  9. MOGLAR
    MOGLAR Heavy Load Member
    743
    518
    Jun 19, 2013
    Kansas City , MO
    Check to see if you have a "Quick disconnect" switch for the batteries. Its a lever thats between the battery box and the engine. These can develop a short and cause starting issues.
    Also you could have a bad starter solenoid.
    Make sure all your batteries are good also.
  10. addrenjunky
    addrenjunky Light Load Member
    66
    80
    Jan 28, 2015
    wisconsin
    I have the same truck with same issue. It has failed to start 3 times in past 2 months. It indicated trans in nuetral and went through the prestart checks but no crank. Once I got it to start by pressing on the brake pedal. The next time it wouldnt crank pressing the brake did not help, but got it to crank by turning off the battery disconnect switch for a few minutes. The last time it failed to crank niether of above would work and it got towed into volvo after they put a new starter and solenoid in it and it still wouldn't crank. Shop calls monday saying they can not get it to duplicate a no crank and no active codes. I pick it up and it doesnt get shut off till I get home. It goes in to dealer where purchased and they refashed the ecm and it hasnt acted up since.
  11. Lorne780
    7
    Mar 23, 2016
    Sounds like the same problem I have, what year and engine do you have?
