2016 7500 sensor readout help?
Discussion in 'Refrigerated Trucking Forum' started by 062, Apr 29, 2021.
  1. 062
    062 Road Train Member
    6,351
    34,019
    Oct 20, 2013
    Today while waiting on the system check I scrolled through the sensor readout.
    Delta-T showed 5*
    Water temp showed 32*
    Outside air temp was 80* same for box temp.
    @reeferwrencher is the delta-t sensor on the way out?
    Unit is cooling fine down to 40* in 10min. Delta-t shows -22
    reeferwrencher Thanks this.
  3. reeferwrencher
    reeferwrencher Medium Load Member
    617
    1,577
    Aug 4, 2018
    The delta t is the difference between supply and return air which at -22 is very good.The water temp reading 32 in an 80 ambient air is strange though, what s it reading now after running for a while?
    slow.rider and 062 Thank this.
  4. 062
    6,351
    34,019
    Oct 20, 2013
    Water temp was 176* after 10min.
    I didn’t know that delta-t was temp differential.
    I had a sensor go bad last summer inside the trailer. I forgot the name of it,but it was diagnosed by being a huge difference between it and the other sensors.
  5. reeferwrencher
    617
    1,577
    Aug 4, 2018
    Yeah they should read close when the unit has sat empty and not running for a while maybe a bit of variance.The water temp is normal at 176 when running,sounds like you,re good to go.
