2016 T880 Windshield washer does nothing
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Canned Spam, Jan 5, 2016.
  1. Canned Spam
    Canned Spam Road Train Member
    1,504
    2,906
    Mar 8, 2010
    STL
    I can't figure it out. Can't find a fuse, or anything that would prevent it from working. Was wondering if you guys had any ideas on what or where to check. It's not my truck, I just drive it, so I can't just take it to the dealer despite my repeated request. Hasn't worked since new, it's frustrating
  3. Hick
    Hick Heavy Load Member
    928
    1,624
    Dec 4, 2014
    SAFETY!!!!!!!!!!!!!
  4. ShooterK2
    ShooterK2 Road Train Member
    5,533
    89,470
    Dec 14, 2012
    Oklahoma
    Unplug the squirter motor at the bottom of the washer bottle, and check for power (use a test light and have someone press the button in the cab at same time). If it has power, it's the squirter motor thats bad. If not, it must be a fuse.
    MJ1657 Thanks this.
  5. sdaniel
    sdaniel Road Train Member
    5,511
    4,420
    Sep 7, 2011
    Pelham N.C.
    they did not pay the extra for windshield washers?
  6. Highway Sailor
    Highway Sailor Road Train Member
    1,328
    1,659
    Nov 23, 2011
    Erie,Pa.
    Check the connector attaching to the pump motor. If it's the same on my 2016 Pete ,it comes loose sometimes (every time I need it). I push it around and it works for awhile. I heard they put zip ties on it now.
  7. blairandgretchen
    13,950
    76,719
    Dec 9, 2011
    South west Missouri
    Check washer fluid level.
    Check washer fluid pump motor operation while someone else holds the button.
    My one had the line come loose, so was operational, just not delivering the fluid.
  8. Lyle H
    Lyle H Road Train Member
    1,292
    2,942
    Apr 16, 2014
    The little rubber or plastic lines tend to plug up too.
    blairandgretchen Thanks this.
  9. JPenn
    JPenn Road Train Member
    1,829
    1,874
    Mar 5, 2008
    Northern Tier PA
    I've had the motor soft-seize or get stuck...rapping it a time or two lightly with a screwdriver handle sorted it out. We had one T880 in the fleet at my last gig...everyone either loved it or hated it.
  10. AModelCat
    164,847
    Or ground side is bad.
