24.5 or 22.5 tires, help me decide?
Discussion in 'Experienced Truckers' Advice' started by TNSquire, Oct 6, 2023.
  1. TNSquire
    TNSquire Medium Load Member
    571
    1,967
    Oct 13, 2016
    Decatur, TN
    I was perusing the used trucks today and came across a couple instances where decent trucks had 24.5 tires.
    Correct me if I’m mistaken, but if i wanted to swap to 22.5’s, how big a pain would that be to achieve?
    Just trying to wrap my head around this idea…
    Thanks in advance
  3. Last Call
    Last Call Road Train Member
    7,568
    45,915
    Mar 15, 2021
    Its not a big deal your just going have to pony up money to buy tires & and wheels ..
    Gona lost alottle bit of MPH. also
    Lonesome, MACK E-6, Oxbow and 5 others Thank this.
  4. TNSquire
    571
    1,967
    Oct 13, 2016
    Decatur, TN
    Is there a disadvantage to the 24.5?
    I seem to see 22.5 most commonly, and the 24.5 seem to be more expensive
    Rideandrepair Thanks this.
  5. Chinatown
    Chinatown Road Train Member
    78,630
    188,835
    Aug 28, 2011
    Henderson, NV & Orient
    Will the speedometer have to be reset/recalibrted to match the smaller radius tires.
  6. Banker
    Banker Road Train Member
    4,692
    16,071
    Aug 19, 2012
    The 24.5’s supposedly have a higher rolling resistance due to more sidewall flex. Certain rigs need the taller 24.5 due to their operation off road on occasion. Some people don’t like the larger gap in the wheel well of the 22.5. I run 22.5 because I need the rig to sit as low as possible due to the height of my loads and I sit very close to the ground.
    Oxbow, Rideandrepair, JoeyJunk and 3 others Thank this.
  7. Last Call
    7,568
    45,915
    Mar 15, 2021
    Probably should be recalibrted .. its probably only going to be off 3 maybe 4 mph
    MACK E-6, Oxbow, Rideandrepair and 2 others Thank this.
  8. Judge
    93,835
    Just throw some 24.5 low pros on, same size as 11r22.5/ 22.5 tall
  9. Last Call
    7,568
    45,915
    Mar 15, 2021
    Your probably correct about rolling Resistance..
    I'am one of the guys you mentioned .. that run 24:5 because I like the ground clearance but mainly because I feel 24:5 Disperse heat alittle better and I load kinda heavy also
    I'am in the process right now for switching to hub pilot wheels .. I''d be lie'n if I said I haven't given some serious thought to going with 22:5 since I'am having to buy new wheels and some tires also
    But I 90% sure I'am gona stay with 24:5 's
  10. Bean Jr.
    Bean Jr. Road Train Member
    5,580
    9,945
    Mar 30, 2014
    I run them because that's what it came with! It's slow now, if I changed to lopro, I'd lose to much speed.
  11. JoeyJunk
    JoeyJunk Road Train Member
    8,762
    68,033
    Dec 31, 2010
    Washington, PA
    I bought my truck during covid on a small budget. Came with 24.5. Replaced all tires and 6 aluminum rims (inside rears are steel)
    If I had used my head and spent just a little more money that would have been the time to make the switch. But now that I went from freight to oilfield the MPG’s don’t matter.
    I know if I stay in the oilfield I will be selecting drive tires that don’t hold gravel well. Halliburton runs a Bridgestone that doesn’t hold rocks. Just this week I learned what a cut and chip tire was. Not so sure those have good traction for drives but they are used on oilfield trailers.
