379 Breather huck bolt replacement
Discussion in 'Ask An Owner Operator' started by Bgimnick, Oct 14, 2024.
  1. Bgimnick
    Bgimnick Bobtail Member
    11
    5
    May 12, 2024
    Anyone know the best way to remove and replace the breather bracket bolts on a 379. Trying to install rear breather lighting and the bolts just spin.
    blairandgretchen Thanks this.
  3. 062
    062 Road Train Member
    6,158
    33,276
    Oct 20, 2013
  4. blairandgretchen
    13,262
    70,841
    Dec 9, 2011
    South west Missouri
    I have a huck rivet insert tool I got off Amazon.
    As far as removing the old one - not sure if there’s a tool for that, or just carefully drill out with a step bit.
  5. Bgimnick
    11
    5
    May 12, 2024
    Yeah I figured that much.
  6. Bgimnick
    11
    5
    May 12, 2024
    I’ll do a search on Amazon. Other huck bolt tools I’ve seen are over pneumatic and over $1,000.
    I would attempt to drill out and replace with bolts and a nut, but I can’t get a socket
    or wrench in the tight space to hold the nut
  7. Bgimnick
    11
    5
    May 12, 2024
    Can you post a link to the tool? Did you use blind rivets or threaded rivets to replace yours?
  8. AModelCat
    155,375
    Wore Out is our resident Peterbilt guy.
    sawmill and 062 Thank this.
  9. Bgimnick
    11
    5
    May 12, 2024
    Anyone know what size rivnut or mandrel to use for these breather brackets?
  10. blairandgretchen
    13,262
    70,841
    Dec 9, 2011
    South west Missouri
    I saw the pneumatic ones. Mine is just a manual deal. They’re a little fiddly to use, but inexpensive.
    Just do a search - you’ll find them.
    Bgimnick Thanks this.
  11. blairandgretchen
    13,262
    70,841
    Dec 9, 2011
    South west Missouri
    ref=asc_df_B0B8C44Z2R
    Not the one I bought, but you get the idea.
    Rivnut - or Rivet nut. I couldn't remember the right word. 'Nutsert' comes to mind too. I dunno. I'm not very handy.
    I used mine to install a LED bar on top of my sleeper. You have to keep the tool dead straight as the handles squeeze together, or you'll break the bit. Practice on some thin sheet metal before you go for it. I don't have any experience removing them.
    For the love of everything holy - put some anti-seize on them all before you put them back in.
    I'd take the other ones out to get an idea of the correct size and thread pitch before you buy the tool kit - make sure it has the correct thingy.
    Let us know how you get on.
    sawmill Thanks this.
