379 hood side panel removal/replacement
Discussion in 'Peterbilt Forum' started by mile marker 27, Jan 19, 2022.
  1. mile marker 27
    mile marker 27 Road Train Member
    1,419
    1,739
    Dec 4, 2019
    Got a dented passenger side panel on the hood of my ‘87 379. I order a replacement from 4 States, with a bolt kit. The existing side panel is riveted on. What’s the best way to remove the rivets from the fender, grill surround and upper hood, from the side panel?
  3. pavrom
    pavrom Road Train Member
    3,221
    7,437
    Apr 29, 2012
    NE illinois
    ...i was sure grinder ... would like to know too ...need mine repaired
  4. wichris
    wichris Road Train Member
    4,512
    9,293
    Jan 17, 2011
    Center punch and drill.
    Siinman and mile marker 27 Thank this.
  5. MacLean
    MacLean Road Train Member
    1,382
    4,097
    Sep 12, 2017
    I’d try an air chisel and and punch.
    mile marker 27 Thanks this.
  6. wichris
    4,512
    9,293
    Jan 17, 2011
    You miss with a grinder or chisel and you're repairing the hood also. Takes about 15 minutes to drill them out.
  7. mile marker 27
    1,419
    1,739
    Dec 4, 2019
    I guess you’re drilling them from the outside, inward?
  8. wichris
    4,512
    9,293
    Jan 17, 2011
    Easiest from outside. Just use a river bit. Start beating on them from either side with a chisel and the flange gets out of shape and you don't get a good fit.
    lester Thanks this.
  9. blairandgretchen
    13,981
    76,904
    Dec 9, 2011
    South west Missouri
    After those responses, I'd be thinking about taking it to a body shop with experience. But - I'm a bit timid when it comes to tackling tasks I'm ill prepared or knowledgeable in.
    Bean Jr. Thanks this.
  10. Coolbreezin
    Coolbreezin Medium Load Member
    410
    440
    Jun 11, 2016
    Florida
    PB shops have the special tool to pop them babies out in minutes. Granted there will be a charge for the service. As they pop one off put a bolt in there to hold it in place and drive back to your shop. Remove bolts, replace side panel. Thats my plan for when I do my fenders.
  11. lester
    2,957
    8,087
    Jan 2, 2012
    NW, Iowa
    Aluminum hucks are easy to drill through, the steel ones suck. About the time you are finished you'll find the best way
