60 series won't start, it shut down
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Yamada, May 26, 2023.
  1. Yamada
    Yamada Bobtail Member
    25
    8
    May 16, 2023
    I had a friend look at my engine while It was running and it randomly shut off, there's no power to the fan relay.. the truck turns but doesn't fire up, where should I check?
    I think he was touching some stuff but he can't recall what he touched while it was running
    There was a like a buzz sound before it shut off
    blairandgretchen Thanks this.
  3. blairandgretchen
    13,950
    76,706
    Dec 9, 2011
    South west Missouri
  4. JB7
    JB7 Road Train Member
    1,027
    1,812
    Dec 13, 2022
    Laurel, MD
    RubyEagle and blairandgretchen Thank this.
  5. blairandgretchen
    13,950
    76,706
    Dec 9, 2011
    South west Missouri
    You need to specify - looking at your past posts on this - that it is a 14L Detroit - . . . .
    And follow up with advice you get to further hep you, and post replies as to a solution . . .
    To eventually help others.
    Rideandrepair and JB7 Thank this.
  6. Yamada
    25
    8
    May 16, 2023
    I didn't get to it yet unfortunately, thanks tot he truck shutting down
  7. Yamada
    25
    8
    May 16, 2023
    I have both which were recently replaced... Should I get new ones again?
  8. Big Road Skateboard
    7,115
    40,383
    May 2, 2021
    What truck? Did you check ECM fuses?
    Here's the answer I expect,
    "Big Truck, checked fuses"
  9. Yamada
    25
    8
    May 16, 2023
    Freightliner Coronado 06, I'm not sure which one is the ECM fuse but there were no blown fuses upon checking
    here's a pic
  10. Yamada
    25
    8
    May 16, 2023
    you are correct though.. Big Truck, checked fuses coming to theaters June 10th
  11. Big Road Skateboard
    7,115
    40,383
    May 2, 2021
    N9t sure if those Coronados had them, but look in the battery box. Maybe 2 small blade type fuses in platic holders with s a cover
    Rideandrepair and beastr123 Thank this.
