7500?
Discussion in 'Refrigerated Trucking Forum' started by 062, Jun 19, 2020.
  1. 062
    062 Road Train Member
    6,351
    34,022
    Oct 20, 2013
    2016 7500 display temp is fluctuating between .5-2.5 degrees in less than 2 seconds. When it reached set point of-10 and went to low idle it jumped up to 8 degrees.
    It has rained a lot in the last couple days. Is there a connector that may have water in it or is sensor going bad?
    @reeferwrencher
  3. 062
    6,351
    34,022
    Oct 20, 2013
    Hopefully it was moisture somewhere it shouldn’t have been. Seems back to normal now.
  4. reeferwrencher
    reeferwrencher Medium Load Member
    618
    1,577
    Aug 4, 2018
    It s possible, when its empty you can remove the back panel and unplug the sensor , check in the plug for corrosion or moisture. It could be the sensor too though, depending on the cost you might just want to change it while you have the panel off. Good luck.
    062 Thanks this.
