97 Kenworth Dash air switches
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Notiller12, Jan 24, 2026.
  1. Notiller12
    Notiller12 Bobtail Member
    12
    6
    Apr 2, 2025
    I have a 97 kenworth t800 and are troubleshooting the air pressure switches behind the dash. There is about 5 switches not labeled and I know some are for the cruise control, low air buzzer, and low air light. Is there a diagram of which ones are which? Thanks
    blairandgretchen Thanks this.
  3. blairandgretchen
    14,033
    77,517
    Dec 9, 2011
    South west Missouri
    That's not making a whole lot of sense to me -
    Cruise control is an on/off and a secondary momentary signal switch for set/resume. (Electrical)
    Low air buzzer is electrical buzzer triggered by an air pressure/electrical sensor, low air warning light the same. The air pressure switches are often in a small aluminum manifold block where air lines connect.
    Suspension dump and Diff lock are air operated on lever switches.
    What is the problem you're trying to solve?
